The New Werks B7KE "Kortz Edition" .21 Racing Engine
#181
i just love it... definitly and improvement. I have used horizontal carbs before and like them, but the B7 with the new carb... it seems like a new engine, perfect package...
#182
Is the new carb available separately, and if so, where from?
Thanks.
Thanks.
#183
You would need to enquire with Werks Racing direct on that one. Not something distributors would probably bring in (unless special ordered). Contact Werks Racing at [email protected] - or just buy a new B7
#184
Thanks. I just got a new one from Tower. It must have been old stock.
#186
I really hope it's a false rumour but Star Motori (someone correct me are they still who makes engines for Werks?) has been MIA for a long time. Last weekend saw a Werks sticker on a trolley and was eagerly eyeing for what engine was he driving but couldn't see, yes I have a soft spot for Sirio/Werks engines
#187
We run out of stock all the time lol but we get shipments of engines and spares in every other week. Got a shipment last week and have one coming next week, just like we have the last 15 years. We are not going anywhere
Short anwer is Star is not our manufacturer it is the company that owned the Sirio brand. So when Star had financial problems there went the Sirio brand (which is now in limbo) but it had zero affect on the company that makes our motors other than just the loss of a customer.
#188
#191
The B3 hasn't been released yet, so there will be no direct comparisons on fuel economy etc for a couple of months after the release date (very soon I'm told).
We ran-in a new B3 (supplied to us for pre release evaluation), and one of my customers is using it now - so we will have some feedback on that after a couple of upcoming events.
Check out the Werks Racing USA Facebook page. I posted up some initial thoughts on the engine there a week or so ago.
Torque wise the B3 is very strong on the bottom end through into the mid range. Top end is good for a 3 port, but we haven't leaned things out yet so the real top end has yet to be seen.
For top end you won't beat the B7.
Vety torquey for a 7 port with strong mid through to dazzling top end. Extremely linear while being very strong.
Once again, check out the FB page - there is some great info on there. I can't post a link on here (against the rules I believe), but just search up Werks Racing
#192
With the new carb on the B7 is there a starting or base line setting on the high and low end with a broken in engine?
#193
Safest option is to start with a default rich setting of both needles flush with housings and your idle gap set at .5 to .7mm
Fire up and start leaning the low speed needle until you get a solid idle at the speed you like (we have found the new horizontal HSN carbs end up with the low speed quite a bit further "in" than the original carbs - so you might need a few tweaks to get this ball park setting).
Once you have the idle set (by leaning the lsn) run the car around and set the high speed for the WOT running you desire.
Once your set there, (because you will have leaned the engine some by now) you will find the idle will have raised up some - so address this by now richening the lsn until the idle returns to where you like it.
Do this gradually by running the car around between small adjustments until you get it right.
That will give you a reasonable tune to work with (you can fine tune from there).
Hsn will end up no more than a half a turn or so in from flush most likely (once again the variables mentioned above will determine this).
Lsn will be somewhat further "in" from flush.
Hope this helps
#194
Where can I get a B7 with the new carb?
#195
All Werks distributors should have stocks of the latest B7 with the horizontal HSN carb by now. Larger stockists like A-Main etc may still be selling older stock however. Flick an email to [email protected] and ask about your nearest stockist (who has received the new model).
