Damaged pipe
You can stick a large screwdriver in the stinger, hold the pipe tight and bend it all back in position. But this small dent should not make a difference in noise.
Cap one end with a piece of tire tubing and a hose clamp. Put your schrader valve on the other. Put in 20 psi, and heat the dent. The air pressure will rise, and will push the dent out.
Really, this is easy to pull out, just a few secconds of work.
