Alternative Cooling - University Research Project- Need some help!
Hey guys,
I'm a senior mechanical engineering at Clemson University. I have been very fortunate to be able to do research with our beloved RC engines for my research topic. We are about to begin testing some alternative cooling technologies for our engines that could decrease weight, reliability and (possibly) eliminate overheating-and thus, engine life. I can't really post too much online since it is still considered new research, but I do need some help.
We are trying to select an engine (or two) that the university will acquire for us to test with. The issue is that we can't just use any engine. I need an engine with a very particular profile below the crankcase fins.
We need to be able to machine the fins from the crankcase down until it is flat. We need about 5 mm of space from the top of the crankcase. Ideally, this could be done with a mill from the top down. The result should look something like the very rough picture below.
It can be squared or circular too, but it cannot touch the bolt holes that holds the head button down.
Kinda like this:
http://img.auctiva.com/imgdata/1/6/9...42919418_o.jpg
but with as much contact surface area as possible when the fins are gone.
I hope this is somewhat clear. If you could please take a look at your engine or engines you have laying around to see if this would be possible. Pics would be HIGHLY appreciated!!!
Also, if any manufacturers or distributors want to get involved and help with the project, I can discuss further through email. Please PM me and we can discuss the benefits for both parties!
Thanks guys!
Kinda like this:
Thanks guys!
The crank case you have in your picture is the newest style novarossi crankcase.
You might want to look at the previous style. Still used on the P5XLT. It's a reasonably priced engine as well.
Then you could machine it the same way as that one in your pic, without drilling holes etc.
I think this is going to end up a bit of a challenge for you. The majority of engine blocks are actually quite thin around the sleeve with the fins removed.
You may consider milling the fins to the proper shape, "filling" the remaining fin cavities with something like Alumiweld or similar, and then remachining to shape.
Cooling the side of crankcase is actually a bad place. The buttonhead is the hottest part close to the combustion and also with a tight screwing to the sleeve (low heat resistance) transferring the most of the heat of the sleeve to the head.
If you want an alternitive cooling always use the buttonhead.
I have some experience with what happends when you run your engine in a cold environment. What happends with the piston when it is cold outside ( around -4 to + 5 degres Celcisus, piston wear down on the front beacuse it get to much cooling from the air. I had to put a lexan plate in the front of the engine. We experimented with some coating on the piston, but when cold, it screwed up. Around the exhaustport pston was always ok, since the blocktemp is always higher there. No, luberication is not a problem.
Just saying that a to cold block is not good. If you can get a design that keeps the block equally hot on all sides, this would also benefit piston/sleeve life and in general the perfomance of an engines should go up, not only in performace, but also in it direct effiency.
Good luck :-)
If you want a better cooling you have to think different. You can think of an aluminium sleeve (can lower the temp by 10 deg C of even an aluminiun sleeve with cooling fins which can even lower the temps by 20 degrees C (see attachement).
Other possibillity to get a smaller head for a lower CG is using a heatpipe, something I want to try. With heatpipes you could transfer the heat to the chassis plate.
Changing a current engine for a better cooling can give problems because that engine is made and designed to work with a certain operating temperature where the size and shape of the head has a huge role in it.
How would this be beneficial being these engines require heat? Testing fuel deliver /
Cooling would be interesting.
Heat is required to expand things
The conical shape in the sleeve (also known as taper) will straighten up when the engine is on temperature.
