Nvision - Werks - Orion 2058 the same pipe?
As I asked, Is this the exact same pipe?
I see that all of them is made by LM.
The reason I ask is that I want a 2058 pipe, there is EFRA 2058 on Orion and Werks pipes but I can not see it on the Nvision.
Trying to buy it from Amain, Werks has been discontinued for a long time and I need it fast. However it has to be Efra approved.
Just curious but based on your statement above how then do you explain that there are 2 different lengths of 2013 pipes available???
Normally that is not allowed. What I do know that only the construction of the cconnection to the manifold is free and all I know the fist generation 2013 pipes had a different connection.
Correct yet and still with the 2013 there was an on-road version and an off-road version. The on-road version pipe was about 1 inch shorter than the off-road versions pipe yet and still it was allowed under the same efra number. This measurement is for the pipe only so not with manifold connected. So the assumption that one pipe is the same as another just because it has a number on it is not always true.
