10min+ Run Time Engines?
#121
STS-Leopard 21 with a 7mm restrictor and Nitro-X fuel get 12+mins
#123
Caster Grenade..... 7mm restrictor and %25 nitroX fuel..... 12mins 33seconds
#126
i have heard of guys running there expo at around %50 and there getting 13+ minutes apparently
#127
This is especially true for tracks with long straights. Basically, a lot of guys (myself included) make the mistake of going WOT on straightaways, where the last 20-30% of the throttle slide makes very little difference in the power curve. Basically, once you've reached your peak HP RPM, you're not going to get any more power... no matter how much "more" throttle you give it. At that point, you're just dumping more fuel into the mix. This can actually give you a false "rich" setting on top, when running wide-open (not a good idea for tuning anyways).
Additionally, with many slide-type carburetors, the slide will actually move slightly past WOT, causing turbulence just below the venturi. Again, at this point you're just dumping excess fuel into the mix. The result is less power and more fuel usage.
Using a restrictor and limiting EPA is a huge way of conserving fuel.
Hookem... go talk to Elliott at RCHQ about his EPA setting. He's got an alpha that's pretty much dialed in at 40-50% EPA, and he's faster than just about all of us.
#128
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
#130
As some already have written here, the entire drive-train have a big influence on fuel economy. Ceramic-bearings and everything setup with the right tolerances and right setup on the clutch makes a huge difference.
When Iīm just bashing with my D8 I turn the HSN out 2hours and I get 11,40-12,5 min with a Picco P7-R evo2 (temp 240).
At the track I turn the HSN in about 2hours and temps are at average 210.
But there I havenīt timed it even ones, just fuels it at 8min and are happy with that.
In 99% of the time I donīt need to open the throttle all the way, but for that 1% I still have it setup so I can. If it didn't make any difference I would change the venturi to a different size or shape, as I did.
Expo is good when it comes to fine tuning the last bit, but I see it as a last resort.
Just hove I see it.
Just hove I see it.
