New Novarossi .21 offroad Plus 4
#3721
thanks for all the input guys, I thought I was finally getting my head around tuning, but there is always something to make me go "what the . . . . . ?"
I thought my LSN was tuned correct as I used the exact method defined by Bernard Durand on Vimeo and it returns to idle straight away from WOT & will idle forever. I will richen the HSN a couple of hours (and in turn adjust the LSN) and run some back to back tanks and see how it goes. thanks for all your help.
#3722
I will explain why if you dont understand why but atm I am working
#3728
I rewcently switched from the RC8.2 standard clutch to a Werks (Heavy) clutch system. Would this affect my tune much? The car ran fine but seemed to idle a bit irregular (faster). Almost sounded a bit lean.
#3729
I have the old version. What are the most evident symptoms of bearing failure? Last week, my engine was reving, but wasn't moving as normal. Thought it was the clutch and replaced it. This week, still has issue when the engine heats up a bit. Also can hear a cling..cling sound. Looks like some resistance.
Idles perfectly and doesn't heat up or flame out. Max temp seen is 240 F. How can I confirm without fully disassembling engine?
#3730
Just got back into nitro after 15 years off, picked up a used MBX-6 with one of these mills in it. Previous owner said it had about 2 gallons through it. It still has a good pinch.
Had to scrape a bunch of carbon build-up from the top of piston, but looks good now.
To my understanding the engine come with standard & turbo head. I think this engine has a turbo head because it's got a p3 turbo plug in it. Am I assuming this correctly? The button head has 2 dots on one side & 1 dot on other side.
I would also like to change bearings. Any recomendations for ceramic or steel bearings?
#3731
#3732
Has anyone used 3016 hong nor pipe with the +4 if so any good
#3734
