Flashpoint engine
#46
My flashpoint has really come around. It still has not dropped all the metal pinch, so the motor still not fully broke in. I ran 8.5 minutes pits this past weekend and still had a good amount of fuel left afterward.
I was using a 6.5 restrictor and a 2090 pipe. No back plates or other trickery. This motor was on point.
I feel pretty good about 9 minute pits and maybe even 10 once fully run in and fine tuning.
I was able to grab these this weekend!
#47
Congrats on the win!
#49
JPZ do you have your needle settings. I just got one of these and will be running the same setup as you. Any info would be great to use as a reference point.
#50
I am not sure what my settings are? I can measure my needles with calipers if you like. That is not something I usually do lol. I kept tuning until it was right, good top, crisp on bottom, clean idle, no pinging. I dont ever use temp guns , only on break in. Just to be sure its getting hot enough.
#51
Yeah just the caliper settings. I have the stock settings that flashpoint sent, wasn't sure how far off yours are from that due to the smaller insert and pipe changes. And I never tune to temp either. If she isn't pinging, lean bogging, and blowing smoke she is good to go!
#53
My FP02 was awesome during the 5 minute qualifier .... in the 20 minute main, it flamed out due to low idle setting.
https://youtu.be/NPWfA9uSazY
#54
#60
