Serpent 705
#541
17T Rear Side Pulley
Does anyone know if Serpent have already came out with the new 17T Rear Side Pulley for the 705? Part number? Not the impulse 17T, since it making use of the Pin, which 705 doesn't have.
I'm trying to get a 1:1 Ratio for front and rear, when using a 22T and 47 for the Rear, 15T Centax Pinion for the 1st gear (rest of Centax gears are stock). If i can't get a 17T to replace the stock 18T read side pulleys, what if i were to use a 23T for the front side pulley or maybe change it to 15T or 16T front middle pulley? Will i be getting 1:1 ratio or maybe close, without the need to do a split on the front or rear tires?
#542
I believe that there already is such a pulley listed. Look in the 705 reference guide that came with the kit. Under options, I know I have a 17t pulley listed, just can't remember the P/N.
#543
17T SIDE PULLEY
The 17t side pulley is listed for older car as a pin drive pulley. The shaft need a hole for the pin to drive the pulley for this #801256 pulley!!
Nizam,
Your titanium shaft you got from Jack should have a pin hole to accomodate for this pulley. He makes these shaft to fit for the 835 & 705 to use both pulleys. The 835 18t side pulley is a pin driven pulley not like the 705 with the grub screw.
Nizam,
#544
The part # is 801252,
I already make that question and ammdrew told me , that there is nothing i could do , just put the 17t pulley,,
ciao!!
ciao!!
#545
ciao!!
ciao!!
Does this part 801252 works and fit inside the Pulley Adapter 808265? Or it making use of the Pin?
#546
Originally posted by nizee
paulfitipauldi,
paulfitipauldi,
Yes , this pulley fits this pulley adapter!!
#547
Did you guys bought all those pulleys?
#548
I ordered 4 of them and they still have not show up. I know they exist though since I got 2 from team Serpent at the winternats that I used in the race.
#549
well i didn't have it yet, but my team mate order it at http://www.gasrccar.com/
you can call and contact the owner Lee (i guess) , and make a special order for you!!
ciao!!
#550
Thanks, I will try it. For anyone that is interested, the different gear ratio did help a lot with acceleration, the car felt much "snappier with the 22/47/17 combination, and still more topspeed than you really need....
#551
Re: 17T Rear Side Pulley
#552
Re: 17T SIDE PULLEY
Nizam,
Nizam,
I'm not too sure how the 18T side pulley of the 835 is mounted. But I know for sure that the Impact 18T pulley is mounted on the pulley adapter (9618) which is then mounted with a pin on the shaft.
Both the Impact and the 705 18T pulley shares the same part number (808260). So the 808265 aluminum pulley adapter used on the 705 has the same hole dimension to mount the 18T side pulley (or 17T pulley) as the 9619 Alu. pulley adapter 19t MK-2. Only when you use the 9619, it spaces the 18T side pulley out a little more from the rear bulkhead.
I know because I did this conversion earlier on my Impulse PRO before the 705 and the 24T side pulley has to be spaced out like 2 mm out to get the 18T and the 24T pulleys to line properly. If you have the hollow middle shaft, it's a little longer for the Impulse (or the 705). Even the stock middle shaft for the 705 is a little longer. This made it possible to space out the 24T side pulley by 2mm.
I hope this clears the confusion
#553
Kenji's final drive ratio for the 2nd gear is 5.431. If you use 18T smallest 2nd gear pinion and 46T biggest 2nd gear spur, you arrive at a final drive ratio of 5.459 on the 705. Pretty close to the Mugen.
Also, yes Frederick, you are correct on the top speed. The Impulse PRO / 705 never had any problems with that. In fact too much top speed I must say
#554
Lucky guy ahh!!
ciao!!
Lucky guy ahh!!
ciao!!
#555
tell you what i ran the old centax with the old drivetrain ratios and won or ran in the top ten for three years now, you do not have to have the new 17, 22/47 gears to compete, in fact the car is much easier to drive with the higher ratio, the lower is great on a tight very high traction track, if the track is loose you are better off finding the punch in the clutch, and be able to roll the throttle, the tc3 was always able to go to a lower ratio, that is why it alwasy looks so darn fast...... in heavy comp i have seen little if any diff in most of these cars.. the lower ratio on some pkg lot tracks would be better, but not all, it is just a option, and if it the reason you are not winning, you are really damn good, and need not be asking here or you have other areas that will give you more improvement........ just trying to help you help yourselves and not waste valuable thought and effort over one simple little thing.....
