Serpent 705
Old 06-04-2003, 12:12 PM
  #1696
supra528's Avatar
and does it plug into the wall??
supra528 is offline
Old 06-04-2003, 12:13 PM
  #1697
supra528's Avatar
oh yeah... and i am very interested... could i have a price??
supra528 is offline
Old 06-04-2003, 12:18 PM
  #1698
Originally posted by supra528
will allen wrenches work ?? cuz im goin to get a good set of tools once i get out to whistler and start working... and thnx for the sites
The site below sells the tools u need to assemble your 705.
http://64.70.208.72/speedtechrc/75.html
Alll you need is the following metric size:
1.5mm Hex Allen Wrench *
2.0mm Hex Allen Wrench *
2.5mm Hex Allen Wrench *
3.0mm Hex Allen Wrench
5.0mm Hex Allen Wrench
7.0mm Hex Socket Wrench
* denote (Get another ball Hex Allen Wrench if you can afford) for those hard to reach places.
I would also recommend getting that Hudy GLOWPLUG / CLUTCHNUT Wrench. It include wrench for your CLutch Nut, Glow Plug and the 5mm for your Adjustable pivot ball Nut.
http://shop.hudy.net/info.php3?ID=10...8ccee2e7bbe5f9
Well....hope that helps.
nizee is offline
Old 06-04-2003, 12:27 PM
  #1699
the thing is, i really only want a charger for the rx pack... so what would be the cheapest peak charger to start off with... later on prob. in december ill get a good all in one one.
Then get a normal charger just for Rx and save.
Punisher trying to sell a good charger there, that might save u a bunch.
nizee is offline
Old 06-04-2003, 12:28 PM
  #1700
supra528's Avatar
ok... i will prob get it from him... thnx for all the help...
supra528 is offline
Old 06-04-2003, 12:49 PM
  #1701
supra528's Avatar
PUNISHER... are you gettin my pm's???
supra528 is offline
Old 06-04-2003, 12:58 PM
  #1702
Trader Rating: 2 (75%+)
Cool
GOT'EM
PUNISHER is offline
Old 06-04-2003, 02:15 PM
  #1703
EVOLUTION's Avatar
Initial D,i sent you a couple of PMs can you get back to me when you have some time thanks.
EVOLUTION is offline
Old 06-04-2003, 07:03 PM
  #1704
dg8one's Avatar
hey guys
anybody knows what is the part # for the alum pivot balls?
any of you guys using this?
thanks
nelly
dg8one is offline
Old 06-04-2003, 07:34 PM
  #1705
InitialD's Avatar
Originally posted by nizee
I'm using the Integy (Eagle Racing) 16x5 Ver.6 charger to charge all my pack, 800mAh Rx pack, 2100mAh Tx Pack, Glow Igniter, Starter Pack and even my GPS and GPRS Radio !!!
I didn't know they had GPRS in the states... Much less a GPRS Radio What is that?
InitialD is offline
Old 06-04-2003, 07:38 PM
  #1706
InitialD's Avatar
Default Re: Bodywork and aerodynamics
Originally posted by markp27
Without taking into accout the downforce generated by the rear wing, how important is it to have the cat's body work as close to the track sufrace?
I've lowered my bodywork down a couple of millimeters in the hope that I'll get more "ground-effect" downforce - does this work in practice, or does this effect not scale well onto RC cars.
Cheers, Mark.
I think it works the same as 1:1 scale cars.
Like modellor mentioned, I believe there is a 6 or 7 part articles about bodyshell aerodynamics by Bruno Heremans. Just look it up at mytsn.
InitialD is offline
Old 06-04-2003, 07:41 PM
  #1707
InitialD's Avatar
Originally posted by Devin
hobico chargers. If your going to get the serpent 750 mAH, set it for 60 mAh and it will be fully charged in a little over 11 hours.
For what it's worth, the Serpent receiver pack is 730 mAH. They sell loose 750 mAH AAA with the shink wrap and wires but you need to solder them yourself.
InitialD is offline
Old 06-04-2003, 07:45 PM
  #1708
InitialD's Avatar
Originally posted by PUNISHER
I'v raced (3 quilifers and a 15min main) all day long with one charge on my 800mah RX pack.
Yes, I've noticed that on my 705 with 2 Futaba S9451 digital servos, I use up slightly less than 100 mAH per 5 minute heat. I think in your case, you end up using about 600 mAH which a 750 or 800 mAH pack should do it.
I've read that hardcore racers who use 150 mAH packs that are very light just for the 5 minute heats...
InitialD is offline
Old 06-04-2003, 07:46 PM
  #1709
InitialD's Avatar
Originally posted by JBrake
I am running the RD Logics .15 header and .12 turbo ROAR legal pipe on my car and I can honestly say I can't tell the difference between that and the Nova 2690 set. Though the RD set is much less expensive than the Nova set.
www.RDLogics.com
Agreed. The NovaMega price is nearly double that the RD Logics. But I think they are a little soft. How are you finding the contruction?
So you're saying that perfromance wise the .15 and .12 RDLogic pipes are no different than the 2690?
InitialD is offline
Old 06-04-2003, 07:49 PM
  #1710
InitialD's Avatar
Not neccessary to get a graphite grease. Any grease will do, like the one from your local automotive store or go to your local hobby store and ask them what they use for differential ball grease, they might help u. I personally like the Ronnie grease, made by Ron Paris Racing, but thats the matter of preference.
Or you don't have to put grease in there, like some will advice you or like some of the Driver i know. But then again, its all in the matter of preference.
Yes, it is a matter of preference. But I would think that if something is constantly rubbing against a metal plate, I think some kind of lubrication should be applied.
Anyway, the reason why graphite grease is recommended is because they do not attract dust. Also, not all greases are made equal. Some fly out very easily but some when applied, stick like glue This is good because you do not have to apply grease time and again. I believe Ronnie grease is a sticky type.
You can use Mugen grease or the black AE grease. They are good also for the Centax thrust bearings.
InitialD is offline
