Spektrum for 3PK >
Spektrum for 3PK
Spektrum for 3PK
Old 07-05-2005, 06:07 PM
sparksy's Avatar
Trader Rating: 14 (94%+)
Default Spektrum for 3PK
Anyone running one of these?
I'm looking into getting one, but am a bit cautious with the tales of woe from some users. Is there any way to tell the difference from the origional release and the revised firmware edition?
sparksy is offline
Old 07-05-2005, 10:20 PM
freefallmarine's Avatar
Default dont do it.
Wait awhile, Buddy, ive gone through 2 of them and had to send them back because of glitching problems. So much for no interference...
freefallmarine is offline
Old 07-05-2005, 10:24 PM
I had my first race with the Spektrum last sunday.. mine worked perfectly!
OrAnGe PoWeR is offline
Old 07-05-2005, 10:33 PM
soc123_au's Avatar
I have had mine for 3 weeks now, no glitches so far. Just make sure it is set in PPM mode at the transmitter. So far I rate it as one of the best purchases I have made.
soc123_au is offline
Old 07-05-2005, 10:41 PM
Been running it for a few Months so far, and I think its the best purchase I've made. I've run it with both electric and nitro with no glitching issues.
Mark O'Brien is offline
Old 07-05-2005, 10:44 PM
soc123_au's Avatar
If you are buying it locally (Aussie) it will be the latest version, the importer had run out of the original batch long ago.
Old 07-05-2005, 11:25 PM
What did you guys put to cover the existing antenna hole on your radio?
Old 07-06-2005, 04:37 AM
fastharry™'s Avatar
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
no problems with mine either.....and it IS one of the best things I bought..
fastharry™ is offline
Old 07-06-2005, 05:55 AM
ziggy12345's Avatar
Dremmel out the plastic cover so the short one fits through it
ziggy12345 is offline
Old 07-06-2005, 10:45 AM
thanks ziggy12345.. how about the hole on the original antenna?
Old 07-06-2005, 11:04 AM
k_bojar's Avatar
Trader Rating: 30 (100%+)
At this stage of the Spektrum's cycle, there should be none of the original ones left...Every place inlcuding Horizon has been selling out and have many on back order....
The only you would probably fine one of these "old" versions, is thru a private sale - not a retail shop...
And, most of the original glitching problems were associated with the Airtronics/Sanwa version, not the futaba or KO ones
And, like Harry said, IT will be the best purchase you make for R/C racing...well except for maybe a starter box
k_bojar is offline
Old 07-06-2005, 11:16 AM
ziggy12345's Avatar
Pity its not legal for use in the UK yet. I and many other have them and they are still in the box coz the paperwork is still to be done
Old 07-06-2005, 11:17 AM
ziggy12345's Avatar
You dont use the old anterna so I unscrew it and leave it in the box
Old 07-06-2005, 11:22 AM
I removed the original antenna from the radio as well.. my question was, what did you use to cover this hole?
Old 07-06-2005, 11:37 AM
Rapid Roy's Avatar
I saw a post previously with a link to a company that makes a machined aluminum plug that screws into your old antena hole. It was for the M8 so I don't know if they make a futaba specific one. It looks like a short stubby antena when installed.
Rapid Roy is offline
