Serpent 960....
#3256
Hi I just got a serpent 960. It currently has futaba servo arms and I need to change them to Jr ones. Can someone tell if both steering and throttle servos arms are the same or are they different?
2ndly the mid shaft pulley that runs to the front belt. Are these the same part with all serpent models? (im talking about the standard plastic ones not the upgraded aluminum ones)
Thanks!
Thanks!
#3257
Thanks!
Thanks!
#3258
thanks heaps, i almost ordered 2 identical servo arms.
#3259
#3260
#3261
buy the longer ones, or use the nylon inserts in the axle to stop the dogbone from sliding so far left and right.
#3270
Hi everybody
Can anyone tell me if the Serpent 966-E Motor Mount Alu V2
[SER-904105]
Is good to convert my serpent 960 into a brushless car? can i use that motor mount?
Thank you!
[SER-904105]
Thank you!
