Mugen MTX-3
first off, afm, i with a lot of others, will think tires are most important, if you dont have the right tires you might as well go home. second, 1 way or diff in the front, if you run a diff fill it with 30k and you will be fine. all the tracks i have been to have been this way.
my setup as of now. tires may change but this setup works awesome on most tracks.
front
ride 4mm
camber -2.5
caster 2
toe 1 out
ack: b
droop: 2
roll bar level
rear
ride 5mm
camber -2
toe -2
droop:6
block b-b
shocks stock: ver 0201
front tires 42 shore power tyres 26mm
rear tires: 40 shore power tyres 30mm
works awesome for me at most tracks, if there is more traction, i go to a 45, 42 if there is less i go to a 40, 37.
if it is a big track i run a 1 way and a negitive diff.
front
ride 4mm
camber -2.5
caster 2
toe 1 out
ack: b
droop: 2
roll bar level
rear
ride 5mm
camber -2
toe -2
droop:6
block b-b
ybakoff:
anything you do to lessen rotating mass will be an advantage. how much, who knows. it depends on your driving. but I would say, tou cant go wrong. you just have to make sure you are semetrical in the mods so you dont make anything unbalanced.
I run an Omega picco xt .12 and sometimes(depends on the track and how buzzed I am) beat guys with x 12's ns-3's and even jp motors. 1.3 hp is all what you make of it
aluminum pulleys
guys, i'm building my mtx-3 right now and would like to know if you would recommend if i used the kawahara aluminum pulleys? is there any advantage or disadvantage if i used one? thanks
Re: aluminum pulleys
alloy are heavier, wear faster then cut your belts up!
How would this light weight $hitties look to you?
best,
best,
Originally posted by Ybakoff
Can i drill holes in the first and second gear housing's to make them lighter. Or is the lightened ones that you buy made out of different material.
Will it stuff them or be o.k
One for the pro's.
One for the pro's.
stefan would strongly support you for using it, since he has not experienced any problems using it. If for my humble opinion, I'd rather not spend my money on this kinda hopups.
best,
best,
My prospec came with a 59 and a 52t spur gear is this the same as the regular kits?
some come with 53/59.
Where can i buy a spool for the front?
What servos do you guys recommened for futuba? I run a 9451 Digital in my steering and was thinking of the same for my throttle, but since i only have a 850 receiver pack was worried about the battery drain of digi servos
Is that the car that cty300 is selling?
I got one of ebay last week from him that was in good nick.
Hey eddie is that the kawahara neg dif in your car.
If yes how do you find it works.
alucard13 Where can i buy a spool for the front?
Re: Re: Re: Re: Re: roll centers
brake? what is it? maybe I should really learn what it is and how to use it.
best,
best,
Originally posted by Data
for the punk fish, setting the break should come FIRST !!!!
