Mugen MTX-4
#3843
shock tower
i ve been racing 4 over 2 years mtx-3 now the 4 and have yet brake a front shock tower. sounds like you need to back off the trottle just a bit. no pain no gain.
#3844
Originally Posted by GrandeGixxer
Haven't really hear of the front tower breaking. Is this the next thing? What are you hitting man? These aren't demolition derby cars!
I have been thinking of making the rear shock tower 6mm with two skyline shock towers... Do you guys think it may be too much?
#3845
Riketsu: The front shock tower, I had broke 2 of these at the winternats against those famose STEEL boards, but P-Dub racing http://www.pdubracing.com/products.htm helped out with a new front foam bumper. Since then, I hadn't had a problem. I had made 4mm ones and also if you go thicker than 4mm in the rear, forget about the tower breaking, you will break everything else on the car first.
#3846
Hello rcfoolz, I didn't see a bumper for the mtx4, and was wondering if you were using the mtx3 bumper,thank you in advance.
#3847
Originally Posted by ruicortez
I keep losing the 2ng gear on my mtx4
Any of you had this same problem? How did you solve it?
Thanks in advance
Thanks in advance
I stripped my first gear (2nd 53t) the other day (one that came with the kit) lasted 4 months of racing and practice
get the steel pinions last for ages and make the spurs last longer aswell
#3848
send them an email or call them.
#3849
#3850
Mugen make them as a option part they shoul be on the option part list
#3851
oh and yes they are 0.8
#3852
Here are the part numbers for both aluminum and steel pinion gears:
ALUMINUM 1ST GEAR PINION:
TO724 - 16T ;TO725 - 17T; TO726 - 18T
ALUMINUM 2ND GEAR PINIONS:
TO727 - 21T; TO728 - 22T; TO729 - 23T; TO730- 24T
STEEL 1ST GEAR PINIONS:
TO731 - 16T; TO732 - 17T; TO733- 18T
STEEL 2ND GEAR PINIONS:
TO734 - 21T; TO735 - 22T; TO736 - 23T; TO737 - 24T
#3853
#3854
hey Roger wats the Ninja like??
#3855
Originally Posted by Sow&Steady
mgreen, in that first pic, it looks like that your brake lever is fully forwards even when your carb is fully closed. Does you brake work?
