Mugen MTX-4
#3257
hi Jo, got the belts today, they look promising i will give it a try tomorrow. thanks for the fast shipping.
Originally Posted by Jo Gutierrez
the cvds from the mtx-3 won't fit the rear of the mtx-4 (longer)
mugen came out with a cvd for the rear. and according to peter chu, skyline will also have a rear cvd available in about a week or two.
mugen titanium pivot balls is around $80. 3racing has them also for around $25. i'm not sure about the quality of the 3racing ones. but of course the mugen's are already tested. i may pick up a set from 3racing this week just to see how durable they are.
the rear shock towers..... i replaced mine with a 4mm one just because i broke it on my first night out with my MTX-4. buddy of mine has his still stock after 4 race weekends. my bro didn't break his, but replaced it with a 3mm skyline shock tower just for insurance (after what happened to mine )
#3258
tag,
i'm glad you got it already. i always try my best to ship orders as fast as i can so they can be on their way sooner.
they fit really good. just make sure you clear the manifold. even a tiny bit of clearance is ok as long as it's not touching the manifold.
i really like the tensioner that the mtx-4 has. unlike the ones from my mtx-3, where it goes up and down easily and not solid. i broke a number of exhaust gaskets because of this but now with the mtx-4, that problem is gone
#3259
I made a refined and editable version of the MTX4 set up sheet. But...I don't know how to post it for eveyone to download it. Too large to upload as a PDF (over 1 mb). Could someone PM me and let me how to post a link so everyone can dowload a file from my server. Thanks.
#3260
hi sohlman
i have no idea how to post a large file but i like your idea of editable setup sheet. can you email me a copy
if it's ok, you can forward it to me here: [email protected]
thanks a bundle
thanks a bundle
#3262
LOL
thanks man ... you know, you gotta do what you gotta do!
#3264
done daniel
i will ship it tomorrow morning so you get them right away!
thanks
thanks
#3266
Hi there guys,
Just wanting some help on your Clutch set up please. i am having trouble trying to shim them so if you could help me that would be great thanks. Whats your clutch set-up like etc etc.
Cheers
Cheers
#3267
hi kyoshoracer,
what for a name from a mtx4 driver .
i use 3 bearings inside the clutchbell, and a .2mm shim
under he flywheel cone. thats all
dieter
dieter
#3270
Originally Posted by KYOSHORACER
Hi there guys,
Cheers
Cheers
First, I usually run on tracks that have medium to high traction. I take the flyweights that come with the car and drill out the holes to 3.5mm. I tighten the spring adjuster down so that when I measure from the edge of the crankshaft (novarossi/based engines) to the adjuster it is 9.5mm.
Next shimming. Put the two bearings in to the clutch bell as described in the manual (two on the inside and one on the outside). I add shims right onto the crankshaft until the clutch bell doesn't rub on the clutch shoe. It takes a lot of shims (sometimes 10 or more). Once I have it to where it doesn't rub I add one more shim. Put the clutch bell and thrust bearing on following the instructions. Set the end play adding shims as needed to make it tight, then remove one shim. That is how I have been running my clutch. Don't ask me if that is right, but that is how I have been setting up and running my clutch.
