Kyosho v-one rrr
#931
Re: Front Diff
Originally posted by Kyofan
You'll need the to use the #10 servo saver aka ackerman as well as using different flange balls to lower the steering rods because the ball end will hit the diff if you don't. I used the shock flange balls and a couple of3mm washers to get it to clear. Here are the parts you'll need:
Gear set part # VZ012, Bevel Shafts part# BS107,Diff Joint (19)part # VZ218, O-Rings Part # VZW020-01, 5.8mm flange balls...the ones used on the shocks, part # VZ225
The car has a ton of steering and I might try the # 10 with the mods you suggested.
I also did not remove the flange from the front diff pulley, and it fits just fine. You just need to take your time and evenly tighten the diff during assembly. If you over torque the diff case housings, it will cause the diff to warp and it will not fit properly in the front bulk head.
#932
Hi there, does anyone find any use for the receiver cover on the RRR.... does it really help protect the receiver from fuel spills or is it better to remove it altogether...
btw, at bone stock and stock settings (no biased preloading) the RRR is pretty well balanced
Rt FR - 354 gm
Lf FR - 356 gm
Rt RR - 416 gm
Lf RR - 416 gm
Rt FR - 354 gm
Lf FR - 356 gm
Rt RR - 416 gm
Lf RR - 416 gm
#933
[QUOTE]Originally posted by thescum
[B]Hi there, does anyone find any use for the receiver cover on the RRR.... does it really help protect the receiver from fuel spills or is it better to remove it altogether...
the receiver cover doesn't really get in the way so i decided to keep in on to cover 3/4 of the receiver.
#934
i just read all 32 pages. That was an interesting read.
Here is what i gathered so far, the fuel tank might leak, the rear shock tower will most likely break and you will have to drill out the arms a little bit so the arms won't be so stiff. I still can't get over the fact the the receiver is not covered and there is almost no place to put the wires. The irony is that the fuel tank leaks where the receiver and the wires are.
The plus is that the car is agile and faster than it's older brothers. And weighs lower too. I have the RR and I have some problems with it, especially with the shock, that grounded me for 2 weeks because tower mixed up my order.
What i have learned from every car I had is that a company can redesign a car all they want but with new designs come new problems. I plan to run my RR for at least another year and most likely get the RRR, got to crawl before you can run.
#935
there was plenty of room when i wired my 3r up.
#936
what upgrades did you guys have on your car? waiting for my v one rrr to arrive so might as well buy the important upgrades before i build it.
#937
I would definitely upgrade the rear shock tower and replace the dogbones with universals. I would also add a pipe mount that mounts onto the chassis to replace the stock mount. The stock mount is part of the front bulkhead and is very fragile. You may want to add bearings in the steering. The car really doesnt need many upgrades, its very good out of the box.
#938
#939
compaq888,
do you have a pix of your rrr....
#940
Originally posted by compaq888
I think the wiring space is just about the same in the RRR and the RR, but the safety of the receiver is less in the RRR. I have mine protected from all sides by using a receiver cover on top of my receiver cover.
#941
Cheers
#942
Originally posted by ziggy12345
Use the optional rear camber links that you can fit 2 x bearings in
Cheers
Cheers
Thanks!
#943
no need to put rear universals on the car. leave dog bones on rear. put the universals in the front though.
#944
Originally posted by dameetz
Which rear camber link is this? Is it the same as V1R camber link? Do you have the part no? Where can I order this?
Thanks!
Thanks!
#945
what is the point of using the camber option part?
