Kyosho v-one rrr
#211
Originally posted by ziggy12345
You seem to spend a lot of time on the kyosho sites when you drive a Serpent!
#212
Translated from Japanese, parts to convert RRR Foam spec to RRR Rubber spec:
The front diff. of V-One RRR diff. gear conversion (rubber tire conversion) the occasion where it does, is used with the 24T pulley and set.
* For V-One RRR. * The part No.BS107 ‚× bell shaft which is necessary to the occasion where V-One RRR is designated as diff. gear specification
No.VZ012 diff. gear set
No.VZ203 pulley set
No.VZ204 diff. pulley set
No.VZ218 diff. joint 19 \ 630
No.VZ237 drive belt 387
No.VZ203 pulley set
#213
Whats classes you running next year at Aldershot NiMo? Touring and Open, Both with foams?
Cheers
Cheers
#214
Cheers
Cheers
IC Scale Touring Open
IC Circuit Open (200/235/8th)
Electric
27T/19T/Mod/F1
#215
Originally posted by NiMo
IC Scale Touring Rubber
Electric
27T/19T/Mod/F1
Electric
27T/19T/Mod/F1
#216
Anti wedgy class!! LOL..
#217
As mentioned above this car doesnt need any hop ups. just pick up a few belts and a spare rear shock stay and you are good to go! It is quite tough too
#218
I drove the car today with the stock setup. I was surprised at how nimble the car is. The only words I can use to decribe it are "it drives like an 8th scale". It's not as good as my FW-05R just yet but out of the box it isn't bad. The gearing is much better for this car.
#219
Whats this about the tank leaking?? Anybody?
Cheers
Cheers
#220
Hello RRR Fans,
I am thinking of buying a RRR and i`m wondering if there are any known faults / build quality issues with it.Also i see a few R/RR `s for sale on Ebay - What`s the difference between the 3 kits.At the moment i run a G4 but i`m not 100% happy with it and i fancy trying the RRR or a 710 - which should i go for ?
Thanks for any advice guys.
Tooned G4.
Tooned G4.
#221
Cheers
Cheers
only a few are ok.
strange . . kyosho quality is usually very good.
wonder if we will ever get a replacement tank
#222
Originally posted by prawntoe
alot of the tanks leaked, including mine and alot of the guys I know.
only a few are ok.
only a few are ok.
Where is this leak, and is it caused by overtightening the mounts?
#223
by the front seam of the gas tank....
#224
http://rc-mushroom.com/product_info....oducts_id=3990
hey guys does this include the rear uprights as well? as the pic is to small i cant see...
thanks in advance
thanks in advance
#225
thanks in advance
thanks in advance
