DM-1 Steering Servo keeps failing
OK, I am a bit stumped here. My throttle servo keeps failing on my DM-1 spec, and I am not sure why. I think I just fried my 3rd Hitec servo on it. I have been using these servos (both these exact servos and ones similar) forever in 1/8 buggies an other abusive situations, and never had a failure, and now I have killed 3. They simply stop working. No impacts, just don't work. They get extremely bound up, as if there was something in them that was gummig up the works. I have taken one appart to try to figure it out, and honestly, just not sure. Any suggestions here? I have the stock lay-down setup, and was wondering if I need to go stand-up. I don't want to go on a wild goose hunt and spend a bunch of money on things that are cool, but don't fix the fundamental problem.
Fried servos - Hitec 625, 645, 605.
EDIT - I put my steering servo, which would make more sense, but it is my throttle servo. Sorry ...
For what it's worth, before it fails they seem to have done similar things, in that it almost acts like my ABS is set, in that it pulsates back and forth like it would with ABS. I have used this with multiple radios and multiple receivers, and I don't even think my DX3s has ABS, and it does it in forward as well as reverse, so I can safely say it is not that, but it acts similar. Just a clue if it makes sense to anyone.
DM1
The DM 1 has small bearings that the top small plate fits into.
There should be one at each end of the small plate.
Check to see if you have these in place, and that they are seated completely.
One actually works for the brake throw, which basically is the opposite of the the throttle throw.
Also make sure the throttle linkage is perpindicular <level> to the carb, and is not slanted, also that the throttle linkage is pulling straight. This could also cause it to bind. Excuse the spelling, never was good with the ol book learning.
i use a dx3r all i can say make sure that if does servos are digital or analog, your remote might have to be set to the proper frame rate. mine has an option in the menu called frame rate. it tells you that if u are using a digital servo to put at frame rate 5.5ms and i would assume that there are not digital then you can use 11ms or 16ms. it had to my friend he had digital servos and he never changed the setting so they eventually burned up. check to see if the dx3s has this option. hope this helps.
For one thing, Hi-tech or not, I would ditch the analog
servos. I have seen then do some strange things when
used with 2.4 radio systems, even when the radios signal
is set in the proper mode.
