Team magic G4 wheel off set help
Hi guys im new to the rc nitro world. i have a team magic g4 and have a 200mm body. i am wanting to change the wheels but am confused about the offset? anyone know whats the max and mini offset i can run? at the moment my wheels are 26mm wide @ front wheels (from out side face of wheel to hex is approx 5mm leaving 21mm from chasis side of wheel to hex. is this poitive or negavtive offset?
As far as Ive seen, you can get -1 offset (rims are closer to the chassis center) up to +3 offset (rims sit further from the chassis)
Ohh, and it doesnt only apply to Team Magic cars, goes for all cars.
Cheers thanks for that. But any idea what kinda offset my wheel are at the moment as per above? are these + or - offset? or any idea what th max is i can run without the wheel rubing on the body or chasis?
um they are GRP ARROWS WHEELS AND TYRES (NVX06E) GRPGANDINI.COM
BASED ON THE DIMENSIONS ABOVE ARE THESE +8 OFFSET OR -8?
offset wheels change the rollcenter of that end of the car, if the track width is kept the same. Once you start fine tuning your car to a track, then you can fine tune the roll center through using offset wheels.
The best solution for Team magics Ive found to date are wheels +.5mm-+.8mm, otherwise you will have to buy different hex hubs. I did use offsets to get a feel for how track widths impact the car handling.
You will find that you may also have to cut down our balls on your arms to allow to narrow the track width
This also depends on the CV joints and the pin positions as you may be pushing your dog bone into the outdrives and seizing suspension
Since using capricorn all my problems have been solved. I used matrix and strugled to get under 200mm on the rear.
Last point, I measure various wheels from various mfg and none maintained a similar offset ration front and rear, so you might mix and match.
Well, Im just stating that I have found wheels that sat inside the chassis, but I didnt check if the wheelnuts protruded or not - I think they were Jaco's that I noticed them in.
