Old 03-04-2011, 10:02 AM   #1
BigBellyCat's Avatar
Default Simplicity VS high tech
I'm 'old-school'. I'd rather use direct plug in connectors for my receiver to receiver battery combo. then there are also electronic switches, manual 'on-off' switches, micro switches' etc
I'm curious to know what kind of electrical connection do you all use to the receiver.
A lot of emphasis is about servos and radio equipment, but not much said about the wiring configuration or choice of connectors, or choice of switches. I've been plugging my receiver battery directly to the receiver, and this method is the most simplest one i'm using since it has never failed or came undone in a crash.
besides simple plug in connectors, what are your thoughts on aluminium servo arms? good or bad in 1/8 on road cars??
BigBellyCat is offline   Reply With Quote
Old 03-04-2011, 10:44 AM   #2
Send a message via Yahoo to motojon
if done right the first time will last for awhile....over a year for me personaly, plastic ones usually last 1 or 2 races if ur lucky
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 03-04-2011, 10:46 AM   #3
CanyonCarverR1's Avatar
I've used the Airtronics switch harness with charge port (#97001) or the similar version from JR for approx. 15 years without a single failure. Every new car gets a new switch and I'll change a switch about every 2 years of use.
CanyonCarverR1 is offline   Reply With Quote
Old 03-04-2011, 11:07 AM   #4
Switch harness...i'll look that one up right now...thanks!
Old 03-04-2011, 11:12 PM   #5
gfilos's Avatar
i never use i switch, one thing less to go wrong on a race..
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
DX3R vs Ex-10 peterchia41 Singapore R/C Racers 14 04-29-2008 02:35 AM
