Silicon Oil
Silicon Oil
Can't seem to find any reading material on silicon oil for shocks and front & rear differentials.
Would also like to know tips and conditions as to when you would use a hard silicon as oppose to a soft one.
And which is hard and soft
Is there a website on it?
Would appreciate any info or help.
Re: Silicon Oil
http://gallery.uunet.be/heremanss/index.htm
has alot of good info. very very technical.
basicly if you run on a bumpy track use a softer shock oil. if it is smooth run a harder oil.
although you have to remember that if the oil is too thick it will create understeer and if it is too thin it will turn in to quick maybe even bringing the rear loose.
usually springs make a bigger difference. put in a oil like 55wt or 45wt (v1r oil stock is 40wt i think) and tune the springs from here. unless the track is a permanent set up don't bother with the oil too much.
