Starter Boxs Lipos
Starter Boxs Lipos
Anyone run 2x 7.2 in there Starter box? do you also run a voltage cut off?
Is there anypoint running good lipos.. i heard its best to run a lipo with low c.
is something like this ok?
http://www.rcmart.com/catalog/rc-bat...l?cPath=52_973
as i wouldnt mind another charger.
Pass you soon...
Starter box
How is the car set up doing now. Any better?
havent touched it yet.
gotta get my hudy setup station off my mate.. so i can re-do all the settings.
cant wait till i finally find out what the problem is, as iv checked all the gears and belts.. and no teeth missing, car rolls freely, each wheel rolls freely.. oneway spool seems to be working when i turn the wheels etc.. chassis is straight
im thinking its just the settings.
lil-bump; have u got a link to a lipo u recommend
starter box
http://www.amainhobbies.com/product_...C-148V-2200mAh
Will 2200mah be enough?
Those batteries fully charged would be around 8.4 vdc; so two in series would be 17vdc. A little high for a starterbox. I would run a 1 x 4s lipo. When fully charge would be around 14.7vdc. I think the 1 x 4s would be better than 2 x 2s. I would believe you would want a high S battery. Dual motor starterboxes can draw some hefty current on initial start-up.
If you have two 50 cent coins and your buddy has just one dollar, does he have less money than you?
You could probaly go a little bigger in capacity. I linked that battery for reference only. For a 1/10 it should be okay if you run 1/8 scale you might need a little more capacity. You still should look for some type of battery monitoring system so you don't over discharge your batteries. I just run two 7.2 NIMH myself
I use a 4S with 5000mAh. I prefer to use only one battery since it is less mess of cables and points of posible failure. Mine is like 25C so its on the low side of Lipos. I prefer to use low C numbers just to make the motor last a little longer. Remember that these motors are meant to run on a little over 12VDC.
