Old 03-31-2010, 04:43 AM   #1
Default Starter Boxs Lipos
Anyone run 2x 7.2 in there Starter box? do you also run a voltage cut off?
Is there anypoint running good lipos.. i heard its best to run a lipo with low c.
is something like this ok?
http://www.rcmart.com/catalog/rc-bat...l?cPath=52_973
as i wouldnt mind another charger.
LiL_JaSoN is offline   Reply With Quote
Old 03-31-2010, 06:30 AM   #2
lil-bump's Avatar
Trader Rating: 83 (100%+)
Those batteries fully charged would be around 8.4 vdc; so two in series would be 17vdc. A little high for a starterbox. I would run a 1 x 4s lipo. When fully charge would be around 14.7vdc. I think the 1 x 4s would be better than 2 x 2s. I would believe you would want a high S battery. Dual motor starterboxes can draw some hefty current on initial start-up.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-31-2010, 06:38 AM   #3
Trader Rating: 18 (100%+)
Default Starter box
Jason
How is the car set up doing now. Any better?
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 03-31-2010, 06:42 AM   #4
havent touched it yet.
gotta get my hudy setup station off my mate.. so i can re-do all the settings.
cant wait till i finally find out what the problem is, as iv checked all the gears and belts.. and no teeth missing, car rolls freely, each wheel rolls freely.. oneway spool seems to be working when i turn the wheels etc.. chassis is straight
im thinking its just the settings.
lil-bump; have u got a link to a lipo u recommend
Old 03-31-2010, 06:54 AM   #5
Default starter box
Be sure and check the set screws in the pullies. They could be just spinning on the shafts
nearest barstool
Old 03-31-2010, 06:54 AM   #6
lil-bump's Avatar
Here's a losi from Amain hobbies
http://www.amainhobbies.com/product_...C-148V-2200mAh
Elliott Hart
Serpent America
Desoto Racing Team
Old 03-31-2010, 06:58 AM   #7
musti72's Avatar
Will 2200mah be enough?
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 03-31-2010, 07:25 AM   #8
Let me get this straight... you're saying 2s in series with another 2s has a higher voltage than a 4s battery?
If you have two 50 cent coins and your buddy has just one dollar, does he have less money than you?
olev is offline   Reply With Quote
Old 03-31-2010, 08:04 AM   #9
lil-bump's Avatar
I see your point. Both batteries still contain 4 lipos in series. But I'm not sure what a fully charged 4s battery will peak out at. I know a fully charged 2s will be around 8.4 volts. In series this would be about 17vdc. I would rather have one battery to care for rather than 2.
You could probaly go a little bigger in capacity. I linked that battery for reference only. For a 1/10 it should be okay if you run 1/8 scale you might need a little more capacity. You still should look for some type of battery monitoring system so you don't over discharge your batteries. I just run two 7.2 NIMH myself
Elliott Hart
Serpent America
Desoto Racing Team
Old 03-31-2010, 09:13 AM   #10
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The Losi 2200mah battery is fine for both scale cars. I know more than one guy that runs 1/10th and 1/8th using the losi and they last the entire weekend.
No cutoff being used.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-31-2010, 09:44 AM   #11
lil-bump's Avatar
There you go...
Thanks Scott
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 03-31-2010, 10:24 AM   #12
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I too will purchase the same Losi pack. It will not only last longer than the 12v Gell Cell ( I have gotten one that didn't last a full year) but will make your load a lot lighter. I have the 750 motor Ofna 10th/8th box and this will be perfect.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-31-2010, 03:25 PM   #13
I use a 4S with 5000mAh. I prefer to use only one battery since it is less mess of cables and points of posible failure. Mine is like 25C so its on the low side of Lipos. I prefer to use low C numbers just to make the motor last a little longer. Remember that these motors are meant to run on a little over 12VDC.
jneg is offline   Reply With Quote
Old 03-31-2010, 05:19 PM   #14
I ran two 4900 trakpower battaries in my starter box in series works great also no cut off
ARC R10/2015 - HOBBYWING - PROAMPS - ORCA
BRCCC
elche_83 is offline   Reply With Quote
Old 03-31-2010, 05:33 PM   #15
http://hobbyking.com/hobbyking/store..._20C_Lipo_Pack
would be good if it had tamiya connector
RC Gear OS V-Spec's, futaba servos, Mugen starter boxs, Jammin Pipes, and batterys. robdel24 R/C Items: For Sale/Trade 24 01-31-2010 11:05 AM
