Best servo horns for the Kyosho RRR???
So what has everyone found to be the best servo horns to use on the V-One RRR?
The ones that came with the Futaba servos suck and would need WAY too much cutting and stuff and the kit didn't come with any :( I see that Kyosho has a horn kit (KYOIF435) and they look ok but wanted to see if there was anything better? I need both. Thanks! Alex |
Originally Posted by 92GTA
(Post 6974092)
The ones that came with the Futaba servos suck and would need WAY too much cutting and stuff and the kit didn't come with any :( I see that Kyosho has a horn kit (KYOIF435) and they look ok but wanted to see if there was anything better? I need both. Thanks! Alex You will have to cut the horn at least one side off and you may be able to use the 2nd or 3rd hole. I had to shave my top deck to get additional clearance as well on the front near the ackerman link. http://c0456141.cdn.cloudfiles.racks...p/kop36012.jpg |
Do you have to start a new thread for every question? There already is a RRR thread, put all your questions there, thank you.
Sorry, I will from now on. Doing a search I saw only the FUTM2133 horn suggested and I need the other too.
I always use aluminum servo horns. Trim them to fit as needed. Lots of companies sell them. (Ofna, dynamite, losi etc)
(Post 6974092)
Originally Posted by jca2000au
(Post 6984234)
