Kyosho Evolva
#902
It is different. The threads for the gears are the same but the offset of the gears is different. It also looks like the angle of the clutch bell is different too. Additionally, the Mugen gear pitch is not compatible with the Kyosho so don't waste your time.
#906
I either run 16/20 or 17/21 and 49/45 depending on track size. I have a buddy of mine that runs an entire mugen clutch setup on his evolva. The main reason why I run the mugen clutch bell is beacause I had two Kyosho gears split in two and fly off the Kyosho clutchbell during two seperate races. I never had any problems since switching to the mugen clutch bell and gears.
#908
Re: mugen clutchbell on evolva
Originally posted by kanai2racer
yes the Mugen clutch bell works on the evolva, I currently run the mugen bell on my evolva. What you can't, do is take kyosho gears and try to screw them onto a mugen bell.
#911
If 0.8 module pinion gear is fit, but not standard 1 module pinion gear
#912
hey all,
Finially got to run the first actual full race day on the car. Last time i was at the track the comp shut down. But second time driving 8th scale and i got tq and won in sportsman at RAMS. The car was awsome, great weekend.
#913
need rebuilt
hey, can anyone tell how long you will rebuilt the car ? I found the front wish bone and one way cup weared significantly after a few gallon gone thru.
