Serpent 710
Originally posted by InitialD
Only one Onkel Sow? Does he not have the RING? Anything is possible ya know...
Damn, it's Friday and no pics?
I think I've misplaced by good old Nikon digicam somewhere. Did some tricks on the car with regards to the tank cap and the additional rear shock tower for the body post courtesy of Mark Green. Also did a simple cable tie pull system to grab the car up and open the fuel tank simultaneously for fast refuel.
So what's new in the engine department? Thanks to Goldfinger, I have installed the main ceramic bearing in my engine but have not put in the KHM crankshaft yet.
Anyway, I found the ceramic bearing really tight on the crankshaft. Don't know why. Perhaps its the tight tolerances... With this new bearing, I realised that the crankshaft is kinda tappered very slightly at the end near the crankshaft head / outlet where the main bearing sits. Anyway, the bearing is really light and it spins really smooth.
So many goodies!!!...2Moro Klang?
I just busted my ceramic bearings a week ago...the shield on the smaller bearing got ripped apart and debris went into the engine and did it's thing...
Originally posted by markp27
He's heading in the direction of Highlander now - changed his name to McSow and he is messing with imortality.....must be an age thing
Hope he's not in kilts.
I think I've misplaced by good old Nikon digicam somewhere. Did some tricks on the car [....]
Damn. I thought I could keep a secret but you surely know when to creep in and out to dig secrets.
I know Goldfinger mentioned to me that the Boca front ceramic bearing is not soo reliable and therefore discouraged me to get it. I only got the main bearing.
You tell us all that and then say you can't provide any pics You are cruel!!!!!
Just wanted to see if I haven't loss my touch yet !
ROTF
ROTF
Perhaps. Your morning or my morning? I need to follow somebody. Don't have good sense of direction.
Which engine is this? RRL12 or on the JP? Did it damaged the piston / sleeve?
Thought as much.....you've got the Ring again
Be extra careful with the fit.
Anyways, what time are you planning to go?...It's quite easy to get there. I think theres a map on the Klang thread...
Damn, and all this while i tot i was holding on to the ring. So whats this circular thing in my hands?...
I mentioned previously that there are a lot of false ones going around.
