Serpent 710
#5821
Originally posted by vadn1
Does anyone run 26mm rear tires on the 710 or majority of the racers are using 30mm...? Is it possible to run 26mm in the rear...?
#5822
Re: Re: Re: Re: My car
Originally posted by markp27
Obviously another graphically talented person
#5823
I meant to ask you this earlier - which droop gauge are you using?
Is that Mazda of your's ready yet?
#5824
Originally posted by InitialD
Well, mine is by Eagle Racing ! Cheap but it works well.
Ask crashed_1 !
#5825
Re: Re: Re: Re: Re: My car
Hey Mark, since you use "renegade" OS platforms , I trust you should be graphically talented as well ! Show us some proof !
#5826
Re: Re: Re: My car
#5827
One just for InitialD
Found this one too as I was digging around in my old pics!
#5829
Well, had another look at the car last night. I didn't realize that the pulleys for the front one way and rear diff have play in them. So all I did with both was push them all the way over to one side and that got rid of the wobble. How hard should it be to spin the diff. I mean grab one axle and spin it and hold the other to make it slip? Mine seems quite stiff and I barely have the collar tightened. I figure it will lossen up after I run it once? Thanks, guys, I'll kepp ya posted on how its coming.
#5830
If you mean out of the car when you are holding both axles firm (i.e. left and right) then the diff will only move with a large amount of force. This is the pre-requisite for a well built diff!! Check step 2.4 in the manual - here the diff-tension screw is set, it determines the initial amount of diff "slip".
Cheers, Mark.
#5831
Yes, I'm grabbing by the axles, not the wheels. And it takes a bit of force. So this is OK then? Thanks.
#5832
Insert two allen-keys into the slots of the diff axles and then attempt to turn the diff pulley whilst holding the allen-keys firm (i.e. making sure the axels don't rotate). It should be very difficult to turn the diff pulley.
If that is the case, then your diff setup is fine
Cheers, Mark.
Cheers, Mark.
#5833
Thanks. I'll give that a shot.
#5834
For Marcos
Hey Marcos what parts are to be used to make that mod ?
#5835
To tell you the truth, I stopped using loctite on my car after I stripped the engine screws ! Perhaps I was new at that time and never thought that you just needed a little of it to get it to work.
I only use on the grub screws on the aluminum pulley adapter. I only use on the grub screws on the aluminum pulley adapter.
I don't use loctite on my Centax pinions and on my engine screws as well as the wheel nuts. I just tighten them up very tightly.
I didn't use Locktite on the pinions, no problem whatsoever.
