Lipo Reciever Pack
Lipo Reciever Pack
I am interested in buying a lipo receiver pack for my mtx4r. Whats everyones opinion. Do they last longer on a charge. I have a lipo charger so thats not an issue. What one do you guys recomend or do you not recomend them at all. I know its a novalty thing but they are lighter.
lmk asap
lmk asap
you will also need a regulator........and yes the charge last's longer
no recommendation as i'm a Serpent guy....but i would think any 7.4v reciever pack size. MTX4 has more room than Serpent in the battery placement
lmk asap
lmk asap
Be warned that these batteries can be dangerous. I have had to replace the batteries 2x due to damage caused by low voltage situations caused by a longer than normal storage period between race weekends. I suggest that you should charge your pack to about 1/2 capacity or more before storing the car between race weekends.
When my lipo packs went bad I did not realize that I had a problem until the charger shut off well before it should have when I attempted to recharge the car. It was at this point I removed the battery pack and found it PUFFED up and was HOT! I have heard horror stories of lipo fires created by batteries damaged by charging or physical damage.
Because of this I also started removing the battery pack from the car after a race weekend and storing it in plain view where I could see them during recharge.
Lee
I have run lipo batteries for 3 years. I have a regulator/cut-off to protect the battery. In my opinion, there are 2 main advantages to lipos = 1) they are much lighter so you can add weight (if you have to) where you want it to enhance the handling of the car and 2) the servo speed is very fast right up to the instant that the low voltage cut off shuts off the system. I don't think that they last any longer because 1400mah is 1400mah regardless of if it is nicad or lipo. If there is a difference in time I don't think it is significant.
Lee
Lee
Ok Now you have given me more questions
What lipo Pack do you recomend?
What Lipo Cutoff do you recomend?
Also does this put greater wear and tare on my servos With the higher voltage?
I never had any problems with my servos. I think that the shut off regulates the voltage to prevent it from being too high. I have heard of a lot of people not using a voltage regulator cut off and they had no problems with their servos. I don't recommend this if for no reason than keeping the batteries from over discharging.
Lee
Hi, new here.. I am also interested in buying some Li-Po's for my receiver but have a few questions:
What is recommended 2 cell or 3 cell?
does the voltage have to be cut off at 6v? meaning i would have to buy a regulator?
Is there any recommended mah limit? I am currently using 1400mah Nihm's can i get say a 2500mah Li-Po so it would last longer?
and finally would something like these be suitable?
http://www.venom-group.com/itemdesc.asp?ic=VEN-1559
http://www.lrp.cc/en/products/vtec-b...0-74v/details/
Sorry for all the questions!
Hi Guys
I have the vxr 1300 lipo in my nt1, when it was new it would peak to about 1300 mah when charging but now it only charges till about 300 - 400 mah
should i be concerned?
im using the swallow advance to charge my battery. its been used for about 5-7 race days and i would charge it the night before then charge it before the final
Hi Guys
Lee
