Old 12-28-2008, 08:20 PM   #1
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Default Lipo Reciever Pack
I am interested in buying a lipo receiver pack for my mtx4r. Whats everyones opinion. Do they last longer on a charge. I have a lipo charger so thats not an issue. What one do you guys recomend or do you not recomend them at all. I know its a novalty thing but they are lighter.
lmk asap
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 12-28-2008, 08:26 PM   #2
s10dude's Avatar
you will also need a regulator........and yes the charge last's longer
no recommendation as i'm a Serpent guy....but i would think any 7.4v reciever pack size. MTX4 has more room than Serpent in the battery placement
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 12-29-2008, 05:39 AM   #3
Winner's Circle's Avatar
lmk asap
I have run lipo batteries for 3 years. I have a regulator/cut-off to protect the battery. In my opinion, there are 2 main advantages to lipos = 1) they are much lighter so you can add weight (if you have to) where you want it to enhance the handling of the car and 2) the servo speed is very fast right up to the instant that the low voltage cut off shuts off the system. I don't think that they last any longer because 1400mah is 1400mah regardless of if it is nicad or lipo. If there is a difference in time I don't think it is significant.
Be warned that these batteries can be dangerous. I have had to replace the batteries 2x due to damage caused by low voltage situations caused by a longer than normal storage period between race weekends. I suggest that you should charge your pack to about 1/2 capacity or more before storing the car between race weekends.
When my lipo packs went bad I did not realize that I had a problem until the charger shut off well before it should have when I attempted to recharge the car. It was at this point I removed the battery pack and found it PUFFED up and was HOT! I have heard horror stories of lipo fires created by batteries damaged by charging or physical damage.
Because of this I also started removing the battery pack from the car after a race weekend and storing it in plain view where I could see them during recharge.
Lee
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 12-29-2008, 09:10 AM   #4
CREWMAN's Avatar
Lee
Ok Now you have given me more questions
What lipo Pack do you recomend?
What Lipo Cutoff do you recomend?
Also does this put greater wear and tare on my servos With the higher voltage?
D&K HOBBIES!!!!
Old 12-29-2008, 10:11 AM   #5
I have used a couple of brands - Xceed and Align. The voltage shut off I use is the Novak 5460 (it has a small light in it to let you know when it is on and it also has it's own on/off switch included). I have both of these in stock.
I never had any problems with my servos. I think that the shut off regulates the voltage to prevent it from being too high. I have heard of a lot of people not using a voltage regulator cut off and they had no problems with their servos. I don't recommend this if for no reason than keeping the batteries from over discharging.
Lee
Lee Muse
[email protected]
Old 12-30-2008, 12:29 AM   #6
Hi, new here.. I am also interested in buying some Li-Po's for my receiver but have a few questions:
What is recommended 2 cell or 3 cell?
does the voltage have to be cut off at 6v? meaning i would have to buy a regulator?
Is there any recommended mah limit? I am currently using 1400mah Nihm's can i get say a 2500mah Li-Po so it would last longer?
and finally would something like these be suitable?
http://www.venom-group.com/itemdesc.asp?ic=VEN-1559
http://www.lrp.cc/en/products/vtec-b...0-74v/details/
Sorry for all the questions!
ReX.22 is offline   Reply With Quote
Old 12-30-2008, 07:03 PM   #7
Trader Rating: 13 (93%+)
Hi Guys
I have the vxr 1300 lipo in my nt1, when it was new it would peak to about 1300 mah when charging but now it only charges till about 300 - 400 mah
should i be concerned?
im using the swallow advance to charge my battery. its been used for about 5-7 race days and i would charge it the night before then charge it before the final
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 12-30-2008, 07:48 PM   #8
Originally Posted by mrgsr View Post
Hi Guys
If the pack is swollen or gets hot when you charge it you should be concerned.
Lee
Lee Muse
[email protected]
Team Associated Factory Team RC10R5 tyreguy Electric On-Road 871 10-16-2013 10:35 AM
1/10th 4wd buggy which one? vwjuice Electric Off-Road 83 08-26-2009 12:24 AM
Post Some Pics of Your RC!!! DemonLosi Electric Off-Road 573 01-28-2006 01:34 AM
