How To Make Your Own Foam Wheels??
Any one here ever made there one FOAM wheels??? something in the area od 40 shore???
im looking to find out HOW TO MAKE just the foam donouts does anyone have any insite? |
anyone???
If you have to ask, it's probably way beyond your competence level... but the tool used to cut foam donuts is similar to hole saw with 2 concentrical cutting blades, one for the inner, the other for the outer diameter. And the tools I have used didn't actually have teeth, but just sharpened edges. I assume teeth would work as well, after all we have teeth on our tire truer blades.
Of course you also need the material. And glue. And wheels. And true them down. And edge stickers, at least for the rears. And someone to take care of all that. Hardly worth all the effort, when perfectly good tires cost <10$/pair, glued to the wheel and stickers included... |
Well it's not too difficult, almost in cinch infact. You just get yourself some nice thick foam from your local uphoslterer, some razor blades, and plenty of beer and cut some donuts! The first couple won't come out too great and will be pretty horrible but after you gotten through 4-6 (beers), they'll start looking pretty good!:p
Originally Posted by olev
(Post 5009214)
Of course you also need the material. And glue. And wheels. And true them down. And edge stickers, at least for the rears. And someone to take care of all that. Hardly worth all the effort, when perfectly good tires cost <10$/pair, glued to the wheel and stickers included... what I need to know is how to mix the things needed my make my own donuts |
Simpel:
- place the donut over the rim - put a large screwdriver between the donut and the rim and make an opening. - drop a lot of glue or kit into the hole (I used yellow slowzapp) - hold the tire and move the screwdriver arround the rim, the glue will bee spread out. - get something fast to hold the rim tight and rotate the rim in the tire so you can line out the sidewall of the tire to the rim - wipe off the left over glue If you want to do large numbers you can make a small machine. Use something like a RC airplaine starter and mount a tube on the shaft which is bigger than the donut. If you place a donut into it and start the motor the donut will set itself to the wall of the tube by the rotation forces. Then it is possible to shove in a rimm with a glue layer. Stop the motor, the donut will shrink again and set itself arround the rim. |
I did a google search on this subject and didn't find much. Here is what I found.
http://www.rc-truckncar-tuning.com/rcfoamtire.html This really just talks about the different compounds. Please post any info you find. Good luck, Joe |
Originally Posted by Joe Maxey
(Post 5010542)
http://www.rc-truckncar-tuning.com/rcfoamtire.html This really just talks about the different compounds. Please post any info you find. Good luck, Joe Now if i can only get my hand on HOW TO make the foam itself id be set |
(Post 5009214)
Geez mate hope you know you will be taking on a massive project. Mu mate has made 8th circuit tires and 10th. He ha his masters in rubber technology and taken him about 8 years to produce tires. Mllions of chemicals, cure temps, humidty, also from what I can understand to get the rubber o foam is also a dog. Will post some pics of his tires, they were more rubber based than foam, so wear was awesome but I kept losing the rear end in the tight s`s. Got some fronts to work, we run a sealed track so it did not help the high rubber tire. Would like to see what they do on a very abbrasive track.
Good luck though:) |
How big of a tire do you want for a monster truck? I've talked to some who wants to race a HPI 5B onroad and he was going to get 1/4 scale tires adapted for it. Check his website
www.suhracing.com Maybe this is what would fit your needs. |
why not call a tire manufacturer like bsr and ask for custom donuts in the compound you want. Very easy process for them and I am sure for $50 a donut they would make you some next time they cut a bunch of that same type of foam.
http://www.bsr-racing.com/about/ probably going to be your best shot, ask for monti or john |
Originally Posted by Loveless
(Post 5010673)
Yo Olev, whats the side sticker for, do they protect the tire at all?.
The original poster has now gone from making donuts to producing the foam itself... I'm afraid that's not something that can be taught over internet forum, people actually go to schools to learn about chemistry and production stuff. It's not quite as easy (and harmless) as baking a cake, although most people these days can't even do the latter... |
(Post 5031502)
Yes they do, at least my experience seems to confirm that. Without the stickers they chunk more easily. The tire stickers are based on aluminium tape, so they are a bit tougher than vinyl or paper. The rears need this more than the fronts.
