1/8 2wd onroad?
1/8 2wd onroad?
does anyone make a 1/8th 2wd onroad with an independant suspension? i've seen some without a suspension, but want some adjustability. i am not talking about taking the front diff and side belt out of a current 1/8th, hope someone can help
thanks
thanks
Most people made 2wd 1/8th's up until around 1995 or so when the class died out completely. You may be able to find and old Serpent Vector or Picco Integra set up for 2wd. The cars were identical to their 4wd cousins except for the lack of front drive train and came fitted with a rear diff.
The Motoninca P8 classic does have some suspension but due some rules it has to be a solid rear axle and they managed to setup a rear axle with camber and to-in adjustments.
http://www.motonica.com/italiano/products/products.htm second car down. This car is available in the US, PM me for details. 2wd is raced in France I think, there are a couple of manufacturers other than Motonica making 2wd cars.
The Motonica P8 Classic has toe, width, caster, camber adjustments and I think the chassis flex acts as the 'suspension'. This class would be a great low price alternative as you would not need a fast motor, tires last longer than in 4wd, and of course the cars are cheaper than the 4wd cars.
Doesn't need a fast motor, then why does that thing have a 35+21 sitting on it? hahahaha JK.
If you could get the companies to give you an active rear diff like in the old 2wd 235mm cars, then you could convert the car to 2wd and have like a 1/8th scale touring car class (Serpent still has some old 1/8th scale touring bodies floating around). The could probably be a good spec class to introduce 1/10 scale touring guys into 1/8th scale onroad.
Awesome looking car.
I ordered a Motonica Classic from Garen. I plan on having it out to Toledo before the end of the year.
