Picco Plugs
Picco Plugs
I am currently running a picco .21 with ofna plugs. I am wondering what brands of plugs will fit the button correctly. I know that os plugs do not and was wondering if all of the italian engines use the same style plugs?
If it is a non-turbo engine, any long plug will work (OS is short). O'Donnel is good.
If it is Turbo, OS, Dynamite, Merlin all work well.
For turbo plugs GRP,OS, and Sirio will fit.
ITS TURBO AND THE OS ARE DIFFRENT AND LEAK. The shape of the plug is considerably diffrent. The distributer of the engine also confirmed that the os plugs are diffrent, but I am trying to find plugs that are the same deminsions as the picco plugs.
I have a Picco .21 engine and have tried almost all the plugs (except Merlin cause I don't know whos carry them) beside PICCO....OS plugs are by far the CLOSEST thing that you can get BUT it is not perfectly fit. It does get the motor started, get the car moving, however, after your run, you will see FUEL came out from the plugs area, that indicated the plug was not perfectly sealed. Hince...some minimal air leak....not the best performance.
MEGA and PICCO plugs are the best that you can use....however, that is also the reason I am going back to NOVA ROSSI....good luck finding PICCO cold plugs and ready to pay top $$$ for them...they are hard to find and the most expensive compare to any other plugs even the Nova Rossi one....
Not flaming...Picco engine are FAST, just on my case, it blow plugs like every 2 runs or so....and the way they blow plugs, I just cannot afford to spend $50 or so per race day JUST to buy plugs....nor I can buy any.
I have several PICCO engines and have run OS plugs more than any other brand. They do not leak. Perfect seal every time. Anyhow, Merlin re-designed his turbo plugs to fit PICCO.
Howard (solara), I have at least 5 PICCO head buttons that have never leaked with OS plugs! I have plugs blow when I run too lean or have the engine under-shimmed. I have not been happy with the PICCO plugs when I tried them.
Did you ever put a Nova plug in it? If so you may have distorted the taper in the head a bit. Do not use Nova plugs in a Picco. They may work but I would not advise it. Picco, Mega Picco's and Ofna's would be the best bet.
Picco says to not use os plugs period. THey say you can use them and tighten them really damn tight, but a picco plug will no longer work. So does anyone REALLY know if a picco plug is diffrent than all of the others or are there plugs that actually work. If there is not, is it common for buttons off of other motors to fit one another? 12 dollars a plug isnt right from my standpoint, running offroad.
Picco will only recommend you use picco plugs(that's money out of there pocket). If your unsure take you cooling head off and look at the burn room of your engine thru a magnifing glass(with the plug installed. You will actually see how the plugs fit's inside the burn chamber. If its a turbo plug it should fit absolutly flush. Compare this with a picco,os and mega.
On a dutch forum I started something to get all plugs in a chart:
