Rc10ntc3
#601
Regional Moderator
Just an FYI:
I bought a new chassis make by GH for the Nitro TC3. Needed an extra 'cause in our area, we have had some problems with some bending of the chassis after a considerable wreck by the motor.
This new chassis is pretty sweet, much more rigid than the stock one and lighter.
I will try to post a pic asap, but if your interested, call Ratzas and they will hook you up. It costs much, much less than the Hardcore one. It came with alum. motor mounts as well...
www.ratzas.net
www.ratzas.net
#602
we have the same problem.
We mostly run Lola body so made it worst when you land on the engine. It will push the chassis and bend right where the engine mount is.
THe GH chassis I saw looks to be much stronger in that area because of the smaller holes next to the engine mount and 3mm.
#603
ChristopherKee,
Thanks!!
Thanks!!
#605
Originally posted by kansasracer
Just an FYI:
www.ratzas.net
Just an FYI:
www.ratzas.net
thanks
#606
Hmmmmmmmmm, I really don't see how you guys are bending chassis plates. AE uses the same type Aluminum on the TC3 plate as they do the RC10GT plate and it takes more abuse than the TC3.
#607
I also wonder about that . How did you guys bend them?
#608
#609
actually, the chassis is very strong esp with the fold-up edge. But where the engine mount is located, there are two (holes) openning which made that spot weak. so when you land upside down, the engine push and bent the chassis.
Test yours with a ruler, u will be suprise
#610
Now why would I need to test mine with a ruler?? It hasn't been upside down!! Course, even if it was upside down and did bend, there are ways to fix it without spending the $135 Hardcore wants for a Chassis plate. If I do suffer the problems you guys are talking about, then maybe I will agree with you, until then, I'll be happy with my car and not complain.
#611
Regional Moderator
WOW,
It is an option. If you never need another chassis plate, then that's good for you....
MTX2:
Call Ratzas 'cause it isn't on their website. I called them about some micro stuff and Clint and I got to talking and he said he got this way cool chassis in. I think I paid around $55 for mine. It's a far cry from the Hardcore price of $135...
MTX2:
#615
Registered User
If you were going to buy a new chassis, I would look at the one IRRGANG makes, it looks very sweet! I bought all the other hop ups hard core raing makes other than the chassis, and I was displeased with the the upper deck, for $65 dollars they could do better, All though I can see a torque and speed advantage from the bigger shaft and alum brake hub, more rotating mass in that area does help, if you have the engine to pull it. Warning! the inner steering ballcup rubs the bottom of the larger driveshaft, if you turn it as deep as it will cut.
