Rc10ntc3
#1906
I used Jaco nitro shoes. 30mm 40 shore rear and 26mm45 shore fronts. The were excellent. Gr8 wear.
#1907
here is pic of my car tell me what you think
#1908
check out the switch
#1913
Nice car, but with all the time and money you spent on the parts, it's a little dirty for pictures! Oh well.
Anyhoo, just hope nobody hits you in the switch, because if they do that could be very bad times for you. I can already see what happens, they hit you in the switch, it turns your car off as well as breaks the switch, and no more racing for you unless you wanna direct hook up or you replace your switch. Very bad times...
Anyhoo, I've had luck using the TRC double purples. The grip is good on most tracks I've been on. I can probably get like 15-20 tanks off a set before they are "too small". They're still usable, but they'd be better off on a carpet sedan. Plus the TRC's look cool.
#1914
Originally posted by Twist 2 Go
How many tanks are you guys getting per set? I have my car set to where I get no coning front or rear but I can only get 8-10 tanks per set. I have been using TRC or SpeedMind 40-42 shore. 26mm wide. Do the 28/30mm tires last longer or just enhance handling? What is a good set of rubber tires to run? Do they wear better. The v-rages that came with the kit were junk. Thanks
#1915
Originally posted by NTC3NUT
bbntc3, Swen,
Plastic cases are cheep, and I have already invested in "The Fix", which I also bought off Ebay. I'll try that first, and I will let you guys know how it works as soon as I do.
bbntc3, Swen,
#1916
anyone got anymore issue with the new tank?
my kit came with the new tank but after running it for 1 tank, i could feel thewashing machine effect especially when 1/4 tank left.
is there a better tank out there? the impulse i drove can always run till dry.. and better milage as well.
please advise.
please advise.
#1917
please advise.
please advise.
Bad thing is that the plastic is not white or clear. It is smoke black / grey. So it's very hard to tell and see if you have how much of fuel is left in the tank especially if you use a clear colourless type of fuel like Tornado.
Else, I heard that a Mugen or a Serpent tank will fit fine with some modifications.
#1918
Is that K Factory tank out already? If so, where to get it?
#1919
Yes, where to get the K Factory stuff - I've looked at my LHS, Tower, Hobby Peeps, etc. and no listings for KF. . .me wants some of that good stuff!!!
