HPI R40 Nitro Car Forum
#4666
Well you guys... I went out yesterday with my frind Federico (serpent fan) and he just placed a OS .18tz into his serpent 705 and that thing hauls ass!!! the only problem was that is was so fast he couldn't control it, so it wouln't recomend it... instead get the ne 3 port version
#4667
hara products?
where can you get hara proudcts? cant find them anywhere
#4668
HarKonnenD
What type of tires do you use for parking lot action?
#4670
I use 42 shore in the front and 35 shore in the back, the toe in in the rear is at 2,5 and no toe in in the front, the camber is also set at 2.5 front and rear, and the height is at 4mm in front and 5mm in the rear, works great!!!
#4671
I think the stock ones are at front 40 shore and rear at 36 shore
#4673
have you tried lowering the car a bit? It's way much better...
did you get the video I sent you?
I have a clip from yesterday racing agaist the serpent 705 with the OS .18tz engine
#4675
OK HERE IT GOES.... SORRY ABOUT THE WEATHER, HERE IN GUATEMALA IT WAS AROUND 75 DEGREES, BUT KINDA HOT!!!
#4676
sorry, not enough space on your mailbox... try this is free gmail you get 1000mb, i'll send you an invitation
#4677
Engine tunning
When tunning an engine, in this case a turbo .12 engine. what's the perfect temperature when well tuned?
#4680
video on it's way!
