HPI R40 Nitro Car Forum
#2416
come on guys there got to be better belts out there...
#2418
Re: 4 gear diff upgrade for r40
Originally posted by senna555
Does any one know the part number required to convert the diff on r40 to 4 gears...it appears that it is a hotbodies part for the lightning.
Jamie
Jamie
#2420
It was out of the Lightning. Try this one: HBC8022
#2421
hey guys,
im having trouble with my R40s 2 speed
when the car was new it was changing slightly early, and then the clutch tightened itself up and the 2 speed stopped shifting.. it seems that it doesnt matter what i try the 2 speed jus wont change!! i also noticed theres a small crack on one of the 2 speed shoes right near the area where the 2 speed shoes meet.. could this be my problem??
#2422
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Re: Re: 4 gear diff upgrade for r40
Originally posted by AMGRacer
HPI makes a complete conversion kit and the extra shafts, but I am not sure whether you can get it in the USA.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGWX3&P=7
#2423
Originally posted by Team-RTR
hey guys,
hey guys,
yes...also,before putting in the new shoes,take an x acto blade and LIGHTLY take off a little bit of the edge of the shoes on the outside where it would hit the bell..
#2424
Re: Re: Re: 4 gear diff upgrade for r40
Thanks for the link!
#2425
Morning back to 'ya....why up so early?....
#2426
Couldn't sleep...
Because my R40 is coming in today
#2427
Can't blame you there..
Take your time putting it together....and remember to enjoy yourself while doing it...Sometimes people forget that......Driving alone is not all there is to this hobby...
#2428
I have a question about putting oil/grease in the diffs.
My buddy who has a R40 said don't put oil in the diffs because they'll leak. He recommended Associated Black Grease.
Is this true?
Is this true?
#2429
you should be able to fill them with silicone oil they come with gaskets
maybe use some rtv also if you cannot get them to seal properly with the gasket
i think the kit set-up uses 5k front oil and grease in rear
i use a one-way and 30k rear and havent noticed any leakage yet
#2430
