HOW TO GET BETTER FUEL MILAGE 1/8 ON-ROAD
Hi guys, looking for things that you have done to get better milage.
I have a 7.5 restrictor in the carb. and running the lowest gear ratio. I backed off on my clutch spring. Running 25% fuel. Engine temp around 250 deg. One extra copper shim under the button.
Let me know things that you have done that gave you more run time. Thanks
http://www.serpent.com/product/200305 will flow a less air than an open foam filter which will require you to lean the motor a little.........a little better mileage..............ALL the fast guys at Toledo run them...don't think they would finish a five minute qualifier w/o one.........
Switch to lower nitro content, eg. 16% or 20%
Change pipe.
And turn off air conditioning
Change pipe.
Run the 2013 pipe, it will give a lot of time.
Also try to lower the tank pressure
what brand is 2013 pipe ?
what do you think with novarossi efra 2052 ?
the 2013 is from sirio and does give 15 to 30 secs more runtime
The last pipe to use when you have fuel problems is the 2052, its a GREAT power pipe but fuel is terrible.
Do you make the 5 min mark?
Try the 2015 for NOVA or the 2018 from MAX, they have good power and they are great on fuel.
HI Roelof how are you doing? hope you are fine, we are great down here.
asw7576, when I grow up I will have the same real car as yours!!!! the only problem is I dont know were more to grow!!!!
more fuel line from the pipe to the tank= less tank pressure, or a pressure chamber can add volume and smooth exhaust pulses for less, but more consistent tank pressure.
the 2031 is not a mileage friendly pipe. i'd go with the 2018 or 2015 pipe. great options for mileage and power.
drive for better mileage also...... roll on the throttle vs. grabbing a handful of trigger off the corners. see what others that make runtime are running for gearing.
Hai Andy, all is fine over here in Holland. the engines are getting faster !
Indeed the 2052 is the last one you want to use in the search of running time but you can use a non-conical manifold to save some fuel.
With the 2013 I have no problems reaching 5 minutes. The Nova engines will have a lower top rpm but lots of power you can compromise with other gearing.
