Understeer
#16
Trader Rating: 45 (98%+)
doesnt that car have a soild rear axel? I think don't have
about how fast do u take the turn? Fast
how does everyone else take the turn? fast than me but they using foam tire.
#17
Originally posted by me43
...how does everyone else take the turn?
other people are the basis of the observation that your car needs more steering in slow, tight corners, so what makes them handle it differently?
#18
hm...
i guess if brake a little it might help
but if you servo throw is less than everyones than yeah u will have under steer
a rear diff. might help
#19
Sorry, I not understand what you mean.
#20
To use rubber tires against foams, you need to use diffs. Rubber tires don't have enough traction, so you have to use your braking ability as an avantage if you use rubbers. Plus the car should become much more stable on corner entry and exit.
Personally, I find one-ways to be fast, but not very consistent on tracks where you encounter tight 180's and sharp angles created by parking lot style tracks.
#21
i think a rear diff. will help alot
because i belive ur car has a solid rear axel
mind checking?
mind checking?
#22
o, ok
the car only has a rear diff.
my bad
my bad
#23
mind checking?
mind checking?
mike, the gt4 rtr comes with a front solid axle, but he bought a one-way to replace it. I would guess he hasn't touched the rear diff.
#24
I am running rear diff.............front one way. OK.......I change to foam tire and do some brake when go into a 180 degree corner.
#25
i thought it came with a soild rear because yokomo makes a kit with a front oneway and a soild rear
#26
In order to properly brake with a one-way, you must first have all things properly set on your car. The front spring preload must be equal on both sides. The rear droop must also be equal, and you should have very minimal rear droop too, otherwise too much weight will transfer making the car lose traction for braking.
Also, you should lower your brake epa to about 2/3 of what you would have if you had full time 4wd. Still with all of this, you still cannot brake and turn simultaneously.
Hope some of that is new.
#27
#28
may I know what is rear droop?? how to measure it?? Pls advice.
#29
droop is a up travel limitor
adjusted with droop screws
#30
mean we measure by take up the car and measure it from chasis to the ground minus ride high??
