Kyosho V-ONE RRR EVO 2
#2776
I'm good,you?This whole diff swapping has been great,I did the R4 way so no changes were made to internal transmission ratio but the KM front diff has less 3 teeth than stock.The NT1 front diff pulley has the same tooth count as stock so another way for those that have access to xray parts.
#2777
Diff
[QUOTE=30Tooth;11838551]I'm good,you?This whole diff swapping has been great,I did the R4 way so no changes were made to internal transmission ratio but the KM front diff has less 3 teeth than stock.The NT1 front diff pulley has the same tooth count as stock so another way for those that have access to xray parts.[/QUOTE You mean as far as the pulleys correct ,the front diff i used the KM housing that holds the bevels gears an use the nt1 cover that holds the diff pulley.The rear diff had a one tooth difference the KM has 41t the triple R has the 42t ,an those R4 diffs are pricey.
#2779
Can I convert me WCE into an Evo 2 or R4? If so, how?
I know Kyosho used to have update kits but I'm out of the loop.
#2780
Kyosho R4 for sale
#2782
#2784
Another question. Has anyone seen or used any of the aftermarket GPM aluminum parts for the RRR? They look very cool but something I would do once the car became retired on the shelf.
#2785
What is the difference between VZ209/209B/209C rear bulkheads?
#2787
If you want them you can have them for free, just cover shipping and I'll send them.
Steve
#2788
#2789
Hi!
i need default setup sheet for evo2 wc
Thanx
H
Thanx
H
