smoking tires......
smoking tires......
.........Is there any tire compound that will smoke when spun, or is there anything that you can put on the tires???
I want this for next year during my towns Chief Wapello Days paraid and maby the 4th of july paraid.
I think it would be neet for the croud to see little tires smokin.
If any tire compound works, it has to fit on a super, but i might get a nitro 200mm by then tho.
Smoking Idea
Right, I have an idea. But you need to prepare a fire extinguisher though..........
well in top fuel racing they used to(not sure if that is what they use now) drive through alcohol. and it heats up really fast when burned so it provided a smokey burn out. although I dont know if and RC car can get enough force down for this to work.
how do you brake lock the front tires if there are no drive shafts for a brake to go on????
i am thinking about how to make the front weels lock up but i am not sure yet.
and my car is 4 weel but i will leave to dogbones on and figure it out from there.
Re: smoking tires......
You would dip your thumb and index on it, then rub the two finger vigorously, it'd produce a gray smoke out of it--as though your fingers were burning hot.
I'll check back with my brother if he can recall what those oil is and will get back to you.
It's definitely a "DOABLE".
try laying down some clorox or bleech on the pavment.ive seen it work with street cars,when they nail the gas beautiful white smoke apear.dunno if itll work with our scale but give it a try.
it is possible but it will require some special fabrication
I will try to get a layout done on the computer with my knowledge about RC cars. it might work it might not.
I smoke my tires................when they're on my Hudy tire truer
heres vary simple diagram. you would have to get a brake right up front so you dont have to make a new dogbone.
also a front brake controlled by a button pressed bt the left and themb would work the best in my opinion
