Old 07-14-2003, 09:50 PM   #1
Default smoking tires......
.........Is there any tire compound that will smoke when spun, or is there anything that you can put on the tires???
I want this for next year during my towns Chief Wapello Days paraid and maby the 4th of july paraid.
I think it would be neet for the croud to see little tires smokin.
If any tire compound works, it has to fit on a super, but i might get a nitro 200mm by then tho.
wilson_bryant is offline   Reply With Quote
Old 07-14-2003, 09:56 PM   #2
GT-4's Avatar
GT-4 is offline   Reply With Quote
Old 07-15-2003, 12:11 AM   #3
doctorj's Avatar
Default Smoking Idea
Right, I have an idea. But you need to prepare a fire extinguisher though..........
doctorj is offline   Reply With Quote
Old 07-15-2003, 01:19 AM   #4
B
someone asked this in car action mag b4 i think
and they didnt have an anwser ...
its up for you to invent it maybe
B is offline   Reply With Quote
Old 07-15-2003, 07:43 AM   #5
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
well in top fuel racing they used to(not sure if that is what they use now) drive through alcohol. and it heats up really fast when burned so it provided a smokey burn out. although I dont know if and RC car can get enough force down for this to work.
corvettecrazy is offline   Reply With Quote
Old 07-15-2003, 08:01 AM   #6
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
to smoke the tires,Here's what you need to do,The car has to be two wheels rear drive,need to brake lock the front tire, and that should works Oh one more thing you need to have hard rubber tires.good luck
OVA is offline   Reply With Quote
Old 07-15-2003, 08:33 AM   #7
how do you brake lock the front tires if there are no drive shafts for a brake to go on????
Old 07-15-2003, 08:51 AM   #8
GT-4's Avatar
DUH!!!!!
Old 07-15-2003, 09:22 AM   #9
OVA
OVA's Avatar
Ok, You didn't say anything about want to drive the car around too,Want to smoke the tires and drive the car.Your bet best it to get the 5th scale car,they have front brake and rear brake independent
Old 07-15-2003, 12:47 PM   #10
i am thinking about how to make the front weels lock up but i am not sure yet.
and my car is 4 weel but i will leave to dogbones on and figure it out from there.
Old 07-15-2003, 05:24 PM   #11
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: smoking tires......
Your question has made me flashback to when I was very young and played with some sort of oil.
You would dip your thumb and index on it, then rub the two finger vigorously, it'd produce a gray smoke out of it--as though your fingers were burning hot.
I'll check back with my brother if he can recall what those oil is and will get back to you.
It's definitely a "DOABLE".
eddiethefish is offline   Reply With Quote
Old 07-16-2003, 08:01 AM   #12
try laying down some clorox or bleech on the pavment.ive seen it work with street cars,when they nail the gas beautiful white smoke apear.dunno if itll work with our scale but give it a try.
shortyboy is offline   Reply With Quote
Old 07-16-2003, 09:15 AM   #13
i had thought about this for about 18 weeks for 3-4 hours a day(english and french class and part of another).
it is possible but it will require some special fabrication
I will try to get a layout done on the computer with my knowledge about RC cars. it might work it might not.
Old 07-17-2003, 01:45 AM   #14
Roger's Avatar
I smoke my tires................when they're on my Hudy tire truer
Roger is offline   Reply With Quote
Old 07-17-2003, 07:31 AM   #15
heres vary simple diagram. you would have to get a brake right up front so you dont have to make a new dogbone.
also a front brake controlled by a button pressed bt the left and themb would work the best in my opinion
How to quit smoking ??? asw7576 Chat Lounge 139 12-08-2010 12:41 AM
Smoking Motor calavera Rookie Zone 28 09-10-2007 12:00 PM
Smoking motors, need help OldSchool07 Electric Off-Road 1 05-22-2006 12:55 PM
smoking tires bumm_off_street Nitro On-Road 6 05-07-2006 07:43 PM
Smoking your tires ajg Electric On-Road 7 07-29-2004 09:03 AM
