3PK not responding in PPM mode?
I have a 3PK radio, it works perfectly in HRS mode, however when I switch it to PPM mode, I have zero response from any of the electronics in my car. I followed the instructions in the manual on exactly how to switch from HRS to PPM mode.
Please help.
Please help.
I think when changing modes like that, you need to switch off the Tx and on it back. Do the same for the Rx.
Look in the electric forum.
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Re: 3PK not responding in PPM mode?
Please help.
Please help.
Yes, the receiver must be PPM compatible.
Originally posted by AreCee
The problem is solved. He was trying to use the HRS Rx with PPM modulation which is why it wasn't responding.
I think he now understands how it works.
PPM = use FM receiver - digital and analog servo compatible
PCM = use PCM receiver ( has failsafe feature) - digital & analog servos compatible
HRS = use HRS receiver ( has failsafe feature ) - digital servos only
