Kyosho Evolva M3
#256
So these would be similar to the 2 carbon braces that the S960 comes standard with? I am not trying trying to start a brand war with that question so please let's not go there, am just a new guy trying to gather info before picking a brand.
Secondly, and maybe I am misunderstanding you, but aren't all the bearing blocks and suspension arms plastic?
#257
Your question here says that "do the carbon stiffeners replace the plastic piece" when I replied, I said ("the car originally did not come with any") I meant is "there is never any plastic stiffeners that came with the stock kit" of course all suspension, bulkheads, uprights, lay shaft mounts are made of plastic.
#258
No offense was intended, just clarifying so thank you. Sent you a PM.
#260
the red shoe is softer than the grey. It yeilds a little better grip, but it isn't quite as consistant over a long race. That is what I found when trying the different compounds. I almost always use the grey shoe.
#262
Are the A,B,and C blocks easy to swap out or do you have to unscrew the rear bulkheads in order to make the change out.
#263
team kamikaze
when will you put the m3 parts online
#265
#267
Well after the long debate of what car to buy, I've decided on the M3. I was going to get the Motonica, but its a little out of my price range.
So thanks to Ric B and www.bartzrcpartz.com.au for hooking my up with a sweet deal.
Can't wait until it arrives and start the build up.
#268
Hi, do you have thats parts in stoctk?
#270
Thanks you for the information, i have the only one M3 in Puerto Rico, find parts is very hard.
