GT class--buggy-based on road!
#3571
I have the Max Velocity parts in my GT1, they're very nice but make no difference in weight at least in Kyosho's case, maybe in DM-1 that seems 400gr heavier.
#3572
Gonzo, the dragon chassis is a decent upgrade from stock. The one Mika mentioned can be modded to work with very little done. The weight on these cars can vary, but my open car is in at just over 3200 grams and our spec minimum here is 3450. The lightweight universals helps and the titanium hinge pin set from lunsford works well.
+1 Spooky the dragon chassis is a decent upgrade for the IGT & IGT2.
IMO Price between the dragon and Kyosho makes it a no brainer too.
I use a ST-R chassis as of now but have used 2 different dragon chassis for 3 seasons with out any problems with fit or strength so you should be fine.
#3573
Plywood would be better than that blue mystery Metal Kyosho makes
I like the Dragon chassis!
Desoto you keep bringing up the fact that the Ofna is heavier than the Kyosho. From what I understand you bought the car a few days before the race, right? You weren't sponsored by Ofna prior to the race were you? If you were so concerned about weight, why didn't you race the Kyosho?
#3574
Plywood!
#3575
#3576
Gonzo, you'll be fine, just try to listen to Bernie & Mike, they know what time it is, OK
#3577
I really love how this class have grown but there are alot of ways to make this class grow so here's my two cents. How about trying to push a class for foam tires at some events because alot of guys have two cars or more like myself and would love to see some of the more establish guys run these cars as well so don't start bashing my idea because our objective is to put water on our Gt class and watch it grow to a ultimate class
#3578
The reason why we haven't pushed foam tires is because they can be costly. A good set of Ipanema rubber tires can cost you about $65 and last you several racedays of hard racing. A set of foam tires maybe good for one raceday (if you don't chunk it). Plus, your ride height doesn't change with rubber tires whereas with foams, it changes as they were, thus changing the handling of your car. The first set of Ipanema rubber tires lasted an entire race season for me (7 races= 21 qualifiers and seven 15 to 30 min mains {depending on what the program called}) before they started to fade any. Can a set of foam tires do that?
#3579
I agree! With these cars rubber is the way to go.
#3580
Or just the crappy Ofna foams that wear out real fast as your description says.
I have 5 races = 15 qualifiers and 5 20-30 min mains on them.
So to answer your question they last a lot longer than 1 race day EASILY.
Also a good set of BSR Foams is $64.00 bucks. Don’t knock it till you try it.
If you go by ofna foam I agree they do not last but if you search around there are GQ, BSR, & others that work GREAT.
99% of us at Blue Diamond run foams so please don't tell me that it's just me.
Foam tires for this application have improved greatly ask Lee at winners circle.
#3581
+1 I AM WITH YOU
JLock have you ever run the BSR foams that Lee at Winners circle sells?
I can see regions having foam tire racing classes but I like the rubber tire better. To me, less expense, no chunking, and can run them almost anywhere (from dusty concrete to prepped asphalt and anything in between). I am not knocking you, just stating my preference.
#3582
Registered User
Hey guys I just started a little business and was wondering is their anything you guys might want to to see in carbon fiber for your GT cars Kyosho or Ofna Dm1. LMK
www.snrgraphite.com
www.snrgraphite.com
#3584
I'm with JLock I prefer to race with rubber instead of foam. I have a tire truer but those that do not have one can really spend tons of money if the track is not properly set up.
