servo help... plz..... help...... plzzzzzz
hi,... i just finished installing futaba s9451 for throttle & steering on my v1rrr.
prob is when i turn them on,... i get this fast clicking sound coming out from my throttle servo. but servos r working fine.... i can turn left & right,... can accerelate & brake.... just that this fast clicking sound is troubling me... what is the prob???
FYI,... i am using 3pks with synthersizer rx... i hv changed to some other channels but still the sound is there....
thank u...
thank u...
digital servos have kind of a buzzing sound when they're under stress, your throttle spring between the arm and ball cup might be too tight but you need some of this stress to ensure the carb will return to true idle.
Is the servo brand new or used? I've heard buzzing, but never clicking. Try removing the servo horn and turn it on. If you still hear clicking, something is wrong with the servo.
thank u...
thank u...
Guys are you all saying only when you hear a buzzing sound in the 9451 there is a problem, because I hear buzzing nearly everytime.
I really thought it was normal with these servos??
no no no no..... buzzing is normal. The clicking mentioned is bad. so buzzing good, clicking bad.
thanks V, I was now getting worried
the sound is more like rattling.
the servo is brand new.
ok... thank u.
i know what is the problem now.
u r right. the sound is resulted by the force against the servo. i took out the servo & let them sit freely... no sound. if i used my finger to push them sligthly... the sound was back on.
so,..... we hv to live with that sound?? nothing we can do???
i just wanna be sure that the sound is a norm... scared something happened to my servos only.
ok... thank u.
If it buzzing sound ( when you twist the horn ) it is fine...... it's perfect.
Always set your EPA ( End Point Adjustment ) when your throttle or steering has reached maximum point, stop there, set EPA, and you should hear the buzzing noise is silent or almost silent. If you keep pushing : two things will happen : 1. rapid battery drainage and/or 2. chipping gear.
i thought the same thing years ago
ahhhh my new servo theres something wrong
but its just the digital servo working. the more force you put on it the more the buzzing will intensify.
nothing more to see here ppl please disperse
