Kyosho VoneR Thread
#5251
well I have to weigh in on the bodies.
I find big differences in handling and lap times based on bodies. Some bodies like the stratus are sorta neutral but to me they push, some like the vauxhall have more steering, some have awesome downforce like the nsx, some are just ill-handling pigs all around like the saleen mustang. Some like the 911 gt2 look great on aero's but are very tail-happy. Not sure why some can't tell any difference between bodies when racing but everyone I race with sure can.
#5252
All the race protoform bodies seem to me to be the same Perhaps if I was really picky I could say some were better than others in certain areas but I would really be splitting hairs. Certainly there is absolutely no difference on the timesheets.
#5253
random thought,
Kyosho should come out with a Kyosho Vone triple R, or something. With a carbon fiber upper deck, carbon fiber shock towers, lower cg engine mounts, super narrow chassis, layed down servo in front, and a super low fuel tank.
Yeah, you can get all the hop ups to do this, but that's alot of cash and what a hassle, just come out with the Vone RRR and make it easy on us Kyosho peeps.
I've been visitin the MTX-3 thread too much... sheeshh..
#5254
lol, good idea, u know waht teh funny thing i noticed about teh mtx-2? there was never an mtx-1
#5255
yeah, ur right...
#5256
lol..............................
#5257
Originally posted by calimassive
random thought,
random thought,
Look at the XRAY and the TC3 (electric one). The XRAY oozes quality is alloy and graphite all over, the TC3 is a big ole hunk of plastic. But the TC3 has proven many times it has the ability to hang with the graphite tourers in the right hands.
#5258
Well I was just having a laugh...
But seriously, ur right, the V1rr is a great car.
Like I said I've been visiting the MTX-3 thread far too often latley.
#5259
Just like to give props to the V1RR whenever possible
#5260
lol,
it would be nice to see some carbon graphite parts though. jus add a carbon graphite radio plate instead of a "fiberglass reinforced one(lol)" and it will look that much nicer, and become that more attractive to racer's looking for a great car
#5261
so its all good. As impressive as the MTX-3 looks, I would never give up my V1rr. Unless the MTX-3 was just hands down the better car, which I doubt.
#5262
Originally posted by racer rich
DCR1TWO-
Very nice looking car! I have one question regarding the graphite upper deck on your car. As you may know, the Reflex comes with a very thin and pliable graphite upper deck. On your Reflex I can see you used an aftermarket graphite upper deck. Is the graphite upper deck on your Reflex the graphite upper deck from 3 Racing? If not, what manufacturer makes it? I was thinking about puchasing an aftermarket graphite upper deck but I was not quite sure if any would accomadate the low CG fuel tank that the Reflex comes with. Did you have to make any modifications to install the low CG fuel tank? Does the aftermarket graphite upper deck your using still keep the low CG fuel tank exactly in the center of the car?
Thank you for considering to answer all these questions!
DCR1TWO-
I myself and a few others hear have the same combo, the only drawback is you need to get a different side brace that has its own side belt tensioner, there is not a space for one on the K factory unit.
The K factory side brace is cool,I have not had a problem with mine.
#5263
RE:RE:RE:RE:RE Bodies
I run what evryone else is useing, as in stratus or accord maybe lola or crowd pleaser
I would say run the one you like the best Damn the ones who know it all
#5264
DCR1TWO-
DCR1TWO-
The tank is still in the center and you will need to purchase the V-ONE R receiver cover to get it to work with the Reflex. You can get the receiver cover from tower part# FM314 for $6.49. You will also have to cut out a small hole in the back of the receiver cover to accomodate the wider/lower CG tank. Other than that, all I did was add thicker o-rings to the tank mount to keep it from flopping around.
Hope this helps.
#5265
Originally posted by HEYALIGNMENTGUY
The upper deck on that car is a K Factory deck and lower CG Fuel tank
