Kyosho VoneR Thread
#511
Originally posted by AMGRacer
Ohhhhhh OK. What setup do you use for your rubber? I also am thinking of running a rubber setup soon.....
stock shock oil
front gold spring and rear stock spring
front black sway bar and rear none.
front shock lowest position and also rear lowest positon. (i run the LOLA body)
chassis ride high as low as possible as we have a flat and smooth track
Front zero toe and 0.5 camber
rear 2.5 rear toe in and 1' camber
camber link on lower hole on rear hub
#512
Manticore do you have a good setup for foam tires on a medium fairly fast track?
I am trying to use the Kyosho setup as much as I can and it is OK, but I feel it could be better......
Thanks!!
Thanks!!
#513
Originally posted by Manticore
i have kyosho LSD in rear and front and mid one-way.
stock shock oil
stock shock oil
We need extra holes...
#514
Originally posted by Diva
The graphite rear shock plate from Five-Star provides one extra lower position than the stock one. I used to mount that lowest position and it provides good rear grip with stock spring. That's the only graphite option I got, not because of the material but the holes.
#515
We all like that, don't we?
#516
The LSD from Kyosho is not really a LSD right? It actually locks the diff as the cars speed increases? Does it do this progressively or is it like a light switch?
I am still trying to understand how this device will affect the handling of my car.
#517
#518
#519
Normal 1:1 LSD are "torque-splitting" devices that can sense when a particular wheel is losing grip and channel more power to the other wheel. These are the "torsen" style diffs. Then there are the old style mechanical LSDs with spider gears and clutches or cone clutches like in the Ford nine inch differentials which increased traction to both wheels as the torque force on the drive shaft increases......
What exacty does the Kyosho diff do? I think it locks both rear wheels as the SPEED increases, not the TORQUE forces right? Or am I wrong. The torque forces are most important as when you mash the throttle from a standstill both wheels should lock. Whereas with the Kyosho they would not lock until the diff speed was high enough? Right??
#520
I think you're talking about the Kawa diff. Yes it indeed locks the diff as speed increases. It prevents the difference in spin rate between the RR and RL when you're pulling throttle out of the corner. I saw many ppl putting this stuff on and the effect is quite obvious. But I don't think it's worth that money.
#521
So the Kawahara diff will lock up when wheels lose traction, but the Kyosho diff locks up when the speed increases sufficiently. Right?
#522
#523
the kyosho LSD designed for corners and to limit free spin and on the straight the diff still work when you steer.
the kawahara diff has no function on corners as the built in clutch isnt engaged at slow speed. and the diff will progressively lock up according to the diff REV and give you higher straight like stability.
#524
the kawahara diff has no function on corners as the built in clutch isnt engaged at slow speed. and the diff will progressively lock up according to the diff REV and give you higher straight-line stability.
amended
#525
Talking about LSD, anyone found out what that black lube is? I'm talking about the Kyosho LSD...
