Mugen MTX-4R
#346
I have a question about gearing. I run the stock gearing 17-59 1st and 23-53 2nd which is a 6 tooth difference. I plan to use a 16-59 1st and a 21-54 for 2nd. Will the gears still line up with a 5 tooth difference?? By the way I love the car!!! It is very tough and drives GREAT. Seems ROCK solid. Troy
#347
Stock gearing is already low....... maybe you set up the centax clutch not right ?
#349
Hy today i ran in my engine.. It took me forever to tune the clutch properly. And theres a problem i cant set my gap like the crankshaft isnt long enough or something. I have a problem with accelariton topspeed is ok. First 1-2 meters it isnt going anywhere then it rotates like it shoud. I have already shortened the gearin(16 pinion) but still the problem exists. I also changed the sping at the clutch from ultra hard to standard, ive changed the whole clutch. I made spring setings from 0.6~1.7mm it was no change. Anyone else had the same expirience..
Oh btw im driving Mtx-4r and a C5 ninja plug..
Please answer,thanks
#351
jet: same problem: set spring at 8.9, put 1.0mm total of spacers under clutch bell and I cannot get .3mm of play...somewhere around .17...I tightened the clutch spring to 9.6 with no help...
only thing works for me is take .2mm out of clutch bell spacers
#352
No that didnt solve my prob. I found out that the trust bearings are different..
I measured it and it was 4.35 i put in a new one and it was 3.95... And so i couldn set my clutch gap. I also found out that i mixed two bearings . One of it has bigger balls and bigger "runaway" another smaller balls..
And when i put both of them together(smaller balls to smaller bushing, bigger to bigger) both were 3.95 and now i think it will work perfectly.
Regards,
Nejc
Regards,
Nejc
#353
#354
Before anyone complains, of course not ALL gears are the same, but for example 2nd gear pinions from 21-24 (or whatever they are) are all the same diameter. The teeth are machined a bit off standard for this to be possible, but this is done on all race cars that I know, to make life easier, so you can use all the pinion/spur combinations.
#355
@corse
Read my post above yours...
Regards,
Nejc
Regards,
Nejc
#356
corse: phew! thanks, you solved my issues, I took everything off got my auto tools and cranked the nut holding the flywheel and the flywheel went down alittle and I can set everything perfectly. This thing has been bugging me for weeks
#357
Rear Diff
What difference does changing the diff oil viscosity make? For instance, if I go up to 30K in the rear, how will it effect the cars performance, compared to the 10K included in the kit?
#358
Cheers
#359
I am stripping spur gears...any advice?
I am stripping both spur gears, Not at the same time but they are both stripping. I feel that I am pretty good with setting gear mesh...maybe not. Any help would be appreciated. Thanks.
#360
Or go to nitrokb.com.
