Locking one way in MTX-4 with JB weld
If I fill the inside of my one way bearing / shaft with JB weld and insert the outdrives will that be enough to lock the front making a spool or will it slip?
Super Moderator
(2) Front diff outdrive cups
(2) 2mm diff pins
(4) 2x6mm FH screws
(4) 2.6mm FH screws
(2) .1mm shims
(2) 5mm o-rings
Mugen, if you are reading this, step up to the plate and start making diff/spool kits. Piecing all of this stuff together is a total pain. I have played this game with the MTX-2, MTX-3, and MTX-4 and it's not fun. If there isn't going to be diffs in the kit, make all of the parts accessible. Currently, getting the diff screws is a total nightmare for many annd I have had to make my own
EDIT CLARIFICATION: I built an "extra" set of diffs for my MTX-2. It came with 2 from the factory. Another mark for my case. It is really nice to have multiple diffs for quick changes at the track.
Nevermind, I decided against it. On second thought, its best not rig such a fine piece of engineering. Instead I ordered the parts to make a proper front spool. Thanks everyone for the input
BIGTACO, just for the record, the oneway/JB job is possible. A buddy and I used to experiment with spare oneways during our old local club races about 4 or so years ago. This was when racers would make spools out of front diffs with Serpent clay or hot glue. Our oneway spools were actually 10g lighter than the common clay methods and had a more centralized/lower rotating mass. It was very balanced and is still holding strong in my old V-one RR/RRR EVO.
But now, I'd buy the Kawahara front oneway locker. Then you can switch hit on your setup changes between a oneway, rigid, or coaxial oneway. It's pretty bad ass!
It's fun when you can make stuff you can't buy, but when you can buy it, save yourself some aggrivation.
Thanks kidDynomite. My track actually had the Kawahara front oneway locker. Should work out good.
