HELP!!!!!
HELP!!!!!
Hey guys i have always wanted a nitro car for 2 years and now i finally got one but i have some little things wrong with it
1. i have been trying to tune it in for 2 weeks now. no success
2. i have heaps of petrol coming out of the exhaust when i push thottle on? is that a problem or normal?
3.steering no matter wat i do i cant get both wheels straight.
4.my idle! also i cant get that right eatha.
If e n of uz could help it would be much appeciated.
Cheers Troy
Cheers Troy
1. All that petrol comming out of your exhaust would mean your running your engine to rich. So turn the top needle (HSN) in a bit, but only a bit at a time (bout an 1/8th, no more than 1/4 at a time then drive for a bit before going in further). Outwards richer, Inwards Leaner.
2.You can't get both straight as in you can't drive in a straight line or you mean one wheel is straight and the other is pointing in or out.
3. Getting your Idle tuned, theres a little tiny screw that sits next to the HSN that you turn in or out, out to lower the idle, in to make it idle higher.
Any other questions, feel free to ask
Hey thanks for them tips ill try them tomorro.
yer one wheel is straight and the otha is pointing in.
but for some reason everytime i brake the engine stalls. i think that is to do with the idle aint it?
plus i put full throttle on and let go the car tends to slide right but also i think that might do with that steering problem!
Cheers Troy
Cheers Troy
To fix the wheels, check your toe in and camber. Your toe in might be a problem. Yep the reason why your engine is stalling when you apply the brakes is because of your idle, work with the idle screw first then do some small adjustments with the throttle trim on your Transmitter if you need to make a few minor adjustments. With you problem with car sliding to the right, it could be to do with your wheels not being straight, or maybe something in your car is locking, Also check to see if your shock springs are fine. That they are both even and you don't have uneven droop or ride height.
alrite will try n check that tomorro.
n ill write how i go.
Cheers Troy
Cheers Troy
The point of my rambling: Before you adjust the idle or anything else on the engine, with the radio and reciever on, make sure the throtle arm on the engine is all the way back to idle position when at idle and when you apply the brakes.
On my car I noticed when the screw for the two servo horns is too tight, they both move together, which gives the engine gas after you apply the brakes. This is what happend to me but didn't realize it untill after it was stalling when i hit the brakes. Make sure this isn't happening to you
heres some pics of what I mean
i have a holden maloo clubsport R8 ute if that is e n help to u all.
i have a GV BV-1 chassis.
Originally Posted by Nitro$junkie
where should i send the throphy
wanker
wanker
It would seem that Holdenluva001 has a BV1 RTR. They come will all sorts of shells, Fords, Holdens and yes, even a maloo clubsport R8 ute. I dont think he was being a smart @rse. I think he was answering the best he knew how.
Good to see you were trying to help out though.
hey viperskull,
Tried fixing it again today and it didnt change . tho when i start it the wheels turn without pressing the throttle. then the glow starter lost charge so itz on charge now.
if it's the sort of clutch set up i think it is, sounds like a broken spring that holds the shoes closed
Take out your engine, then take off the bell housing and inspect the clutch
If clutch is okay, then it still sounds like the throttle arm on the carb isn't at idle position. This will give it gas spinning the wheels, but when you hit the brakes, the throttle arm goes to idle position cutting off the fuel.
If your clutch is good try this: Have a friend hold your radio with full brakes when you start. (From what you said it will not run with the brakes) increase your idle untill it starts, then have your friend let off the brakes (idle position)
if the engine revs up, you know that the throttle arm on the carb isn't in idle position, when your radio is.
okay i managed to get the idle right by using the receiver and the idle needle and doesnt drive automatically, but it still stalls when i brake.
n i was only driving mid thottle now full.
or and i have alot of fuel on the glowplug when i take it out? is that anotha problem
i will get some pictures soon so u can exactly c wat i am talking about.
