Richey Modified Motors
#601
dennis, i have one of your motors and it starts up and runs but i cannot get the temp below 329 degrees. blows smoke out of the exhaust for the whole time that i run (20 min main). we took the temp once i finished racing and it was406 degrees. you would think if it is running that high a temp it would be very fast but it ran fairly slow. any help or advice would be nice.
#602
Motorman(Dennis)
Just wanted to let you know I've broke the track record in the last two weekends out with your motor(2 full laps) the closest car to me was 5 laps behind.Thanks for a outstanding piece of work.
See you in a couple of weeks in Cincin.
THANKS
THANKS
#603
Bob:
Check your low end needle, it sounds like you got the low end lean and the top fat. The low end is what you're mostly on while in the infield going from corner to corner and you only go onto the top-end needle for brief moments at wide open. That is why you still see plenty of smoke, but it won't cool down. Try the pinch test on the fuel line just before the carb and if it revs instantly or dies it's too lean, you should get a count of 3 or 4 one thousanths before the idle rises ( do this after engine is warmed and do a good full throttle run and bring it in and do this quickly ). Hope this helps!
#605
Hey Dennis! I was hoping to get mine back from you ASAP! I got some races comming up and ready to change out motor for the POWER!!!
Andre'
Andre'
#608
Anybody had a problem mounting a stock NTC3 flywheel to a Collari SG shaft. The shaft dia seems smaller. I have a new collet to fit the shaft but it doesnt fit the the Stock flywheel. Am I just confused.
#609
have you checked out the siro engines yep what do you think you could do with that out law 5 port as far as a rto package?after seeing a rtu i have the bug
#610
#612
Motorman
Did you get my email?
#613
Good luck at the Nats Dennis.
#614
dennis, i have a ntc3 and my gearing is 54/48 - 21/27
#615
i bought thru a friend rob medieros. about last july ran it at the nats in houston and have not run it since. i, m pretty sure its the tuner of the motor (me) than anything else. if you could call me at my hobbyshop (703) 492-7788 between noon and 8pm est i would be grateful.
